Old 17-10-21, 01:34 PM   #2471
redtrummy
Default Re: What have you tinkered with today?
Not tinkered with it yet but got the bike out on Friday and as I was turning it over on the starter heard a splat from around the engine area. No more starter but the lights e.t.c still work. this weeks job I guess.
redtrummy is offline   Reply With Quote
Old 19-10-21, 02:03 PM   #2472
garynortheast
garynortheast's Avatar
New handlebar rubbers. The old ones were a few mm too long and the right hand one was preventing the throttle from snapping shut when released.
Old 19-10-21, 04:46 PM   #2473
admin
John T
admin's Avatar
It's called cruise control Gary
Old 19-10-21, 05:19 PM   #2474
garynortheast
Ha ha! In fact I was using it a bit like that John, but I had a couple of instances where I could've done with a quicker throttle response. Time to change them.....
Old 20-10-21, 03:16 PM   #2475
redtrummy
Had a go at my non starting SV. Batt voltage good across terminals 13.5 volts. Tried starting it and listening to the splat noise. Seemed to be around the solenoid. On the last try the dash and lights all failed. Took cover off solenoid and checked main fuse - good. Checked with meter on 10 Amp scale, no sign of any currant draw from the battery. Went for lunch leaving batt on charge. Returned to garage dash lights now back on? Tried starting it again and up it fired!. So I can only deduce that the battery is naff. Will try again in the morning before ordering another one.
Question is why did all the dash and lights go off and stayed off
Old 20-10-21, 07:36 PM   #2476
Adam Ef
Adam Ef's Avatar
Looking at possible winter projects. I still keep going back to the idea of another SV and doing the GSXR fork swap. Problem is by the time you've got an ok SV and some decent forks at prices people are asking you could have just bought a GSXR cheaper and had time to get on with some work (self employed, home work) to pay for it this winter instead of shivering in the garage / garden.
Past:
Old 20-10-21, 07:45 PM   #2477
CheGuevara
I'm looking at parts for a gsxr fork swap and finding prices high as well. I'm sure it was cheaper when I did it a decade or so ago, and the parts were newer and in much nicer shape than most of what's available now.
- K9 SV650S: Hel brake lines, carbon end can
- SZR660: The project...
- K5 SV650S: K7 GSXR750 front end, ZX6RR shock, GB Moto rearsets, Hel brake lines, Renthal risers, Tuono bars, V-Rod headlamp, "JMV" belly pan ~SOLD~ (wonder where it is now)
CheGuevara is offline   Reply With Quote
Old 20-10-21, 10:46 PM   #2478
svenrico
svenrico's Avatar
Weren't most things cheaper a decade ago ?!
svenrico is offline   Reply With Quote
Old 20-10-21, 11:21 PM   #2479
garynortheast
..... you could have just bought a GSXR cheaper
But it wouldn't be one of those nice v-twin SVs Adam.
Old 21-10-21, 12:11 PM   #2480
redtrummy
Well I left the battery on charge overnight and the bike started ok, so to be on the safe side a new battery will be fitted.
Anyone any idea why the dash went completely dead for a while? Strange fault with the battery? Solenoid not releasing causing a short across the battery, but that is unlikely as I think its controlled by a relay.
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
