Old 16-05-18, 08:50 PM   #1
Tamsen Cooper
Tamsen Cooper's Avatar
Default Clear clutch cover- home build
Hi All,
So with the spare engine I featured in one of the videos, I thought it would be cool to use the spare clutch cover I have to have a go at making a transparent clutch cover at home. Now I have read many, many threads, on this site and others about this process. The slight frustration is that many of the pictures are now broken links so I am following mostly words with some pictures online.
So here are my questions I have not encountered
  • I intend to use a drill to cut a series of drilled holes very close to each other to cut out the shape (mine is the plastic cover), is there much chance of the plastic cracking? Hoping to use a handsaw to cut out the detail and file (open to suggestions)
  • I have seen that lexan is suggested by many, of those that have had it for a few years, it is discoloured or is there a better material recently?
  • On the 2002 I have, the oil filler comes into the main centre, some have machined a whole new cover whilst others have made a much smaller hole for a viewing window, which would be a bit of a shame. Has anyone seen a version with a 'cut out' for the oil filler, so the main window is circular but with a small 'chunk' out of it- just wanted to see what it may look like!
Any other tips from people that have had a go/ seen it done?
Thanks as always
New Girl Sets Up YouTube Channel on SV650- see my channel;
Tamsen Cooper
Like, Comment, subscribe
Tamsen Cooper is offline   Reply With Quote
Old 16-05-18, 09:10 PM   #2
Default Re: Clear clutch cover- home build
I've no experience of making a clutch cover, but for something like that I think a hole saw would be a lot easier and neater. Should go through easy with it being plastic
https://www.screwfix.com/p/erbauer-b...00022861107919
https://www.screwfix.com/p/erbauer-1...32-152mm/1779h
Old 16-05-18, 09:43 PM   #3
Tamsen Cooper
That is a good suggestion, I guess I would just have to take it slow but it would make a perfect circle!
Tamsen Cooper
Old 16-05-18, 10:06 PM   #4
netsurfer
I’ve heard of people using the drill in reverse when cutting plastic with holesaws to prevent grabbing and subsequent damage.
YMMV
Would be interested to see the end result
Pete
netsurfer is offline   Reply With Quote
Old 17-05-18, 05:45 AM   #5
I'm wondering whether using some masking tape on the cover before you start the cut would help too?
Might help it to stop it splintering?
I don't have this problem, as I've got one of Nils CNC covers with a clear cover
Old 17-05-18, 07:08 AM   #6
Tamsen Cooper
I’m not sure which one of the designs that is, would you mind posting a picture? (like I said, most thread pictures are now broken links) but I was struggling to see anyone selling one still, and thought it might be fun. I do have an adjustable circle cutter that attaches to a drill- does anyone know the depth of the plastic that makes up the cover?
Tamsen Cooper
Old 17-05-18, 07:36 AM   #7
R1ffR4ff
R1ffR4ff's Avatar
As above.Mark where you are going to drill and then place some masking tape or a couple of layers of cello-tape over the mark so you can still see it.This helps stop plastic splitting and I use this method when drilling into metal as it acts as a sacrificial guide for the drill bit to get it started and stop them skipping.
HTH
Old 17-05-18, 10:33 PM   #8
squirrel_hunter
squirrel_hunter's Avatar
I'm never one to dissuade someone from making something themselves. However...
Cyberdyne Clutch Cover Suzuki SV650
I can see the making of one being an interesting experience, but there will be challenges and you have to consider is the juice worth the squeeze.
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Old 18-05-18, 05:09 AM   #9
Old 18-05-18, 11:54 AM   #10
Tamsen Cooper
That is stunning!! Is he still doing them do you know?
Tamsen Cooper
CLEAR OUT - Lots of different items. Some Freebies too for good home. cbay For Sale - SV's and SV related items 8 20-02-13 01:31 PM
Clutch cover. arcdef SV Talk, Tuning & Tweaking 15 20-12-09 07:13 AM
Clutch Cover carsounds_dan SV Talk, Tuning & Tweaking 17 12-06-08 04:27 PM
Clear Clutch Covers TSM SV Talk, Tuning & Tweaking 18 12-09-05 10:11 PM
Clear clutch covers to see the clutch spin while running. TLRMAN SV Talk, Tuning & Tweaking 13 01-11-04 02:18 PM
