Old 25-07-17, 06:10 PM   #3851
admin
John T
admin's Avatar
Yep, i saw them. Tempted to make a few good ones out of this pile, if I had the skills
Sent from my XT1032 using Tapatalk
Old 25-07-17, 06:42 PM   #3852
Kenzie
Kenzie's Avatar
I know a man...
Old 26-07-17, 06:03 PM   #3853
johnnyrod
johnnyrod's Avatar
I'm not much cop with SLRs. Yet...
Mamiya Six arrived, not quite as described
https://www.flickr.com/photos/bikegu...57686704823046
I wasn't surprised about the case, but the fogged out lens I was. Also the auto-cokking mechanism isn't entirely connected, should hopefully be an easy fix. The shutter seems fine, not measured it but the 1 second runs fine and smooth. Need to email the seller later and see what he has to say. I guess worst case ebay would sort out a refund as it's not fully working and was sold that way. I think he's just started his ebay shop though so I don't want to dump on him too much. This is exactly what happened with the first rangefinder I bought, a Zeiss Contessamat from Etsy, the seller was oblivious to the fungus that ruined the pictures and the sticky shutter and aperture.
Old 26-07-17, 06:12 PM   #3854
Kenzie
Kenzie's Avatar
Do you think you can clear the fogging? You seem pretty adept at stripping things down. Thats five boxes of slides down.
Old 26-07-17, 07:01 PM   #3855
johnnyrod
johnnyrod's Avatar
I don't know, it depends on the cause
Old 26-07-17, 07:18 PM   #3856
admin
John T
admin's Avatar
The A1 has turned up. Condition is really good. Hardly any wear. Alas no battery installed so can't test fully yet. The only issue is the state of the foam seals, they've gone sticky and are crumbling. Of particular concern is the foam damper for the mirror.
Old 26-07-17, 07:22 PM   #3857
johnnyrod
johnnyrod's Avatar
You can get kits or I just cut pieces myself from black 2mm foam from Hobbycraft. The same thing happens with old Pentaxes
http://www.hobbycraft.co.uk/black-se...a4/571989-1000
I've shot with all the cameras I've used it on with no problems
Old 26-07-17, 07:23 PM   #3858
Kenzie
Kenzie's Avatar
Very nice, does Aki Ashai offer a seal kit?
Old 26-07-17, 07:36 PM   #3859
admin
John T
admin's Avatar
£1 a sheet. You can't go wrong with that. Thanks
Old 27-07-17, 02:47 PM   #3860
johnnyrod
johnnyrod's Avatar
Yoko if the price isn't a typo then this is about a hundred quid too cheap IIRC
https://www.gumtree.com/p/non-digita...era/1257466297
