Old 20-03-18, 11:05 PM   #1
Jacobus
Jacobus's Avatar
Default Jumpy tachometer solution.
All right this may be a big help to a lot of people who install a vapor, koso, or digital speedometer.
I recently installed a universal eBay Chinese El Cheapo speedometer tachometer. And like many post I've seen on svrider and other forms there is a problem with the tachometer being very jumpy. I didn't find a lot of information except for a resistor seemed to be the common solution.
So I had to buy the pack off of Amazon that came with several hundred different size resistors. I had to continually add resistance until I found the sweet spot of around 3600 ohms. This is considerably higher than the others but I seem to have had a lot of crap or interference on the wire that I ran. I recommend starting off with three 200 ohm .25 w or 600 ohms like the other forms suggested, and then gradually increase until you find your sweet spot getting rid of the interference that you may have.
I connected my pig tail to the rear ignition coil white wire. Not to be confused with high beams wire. I tried the black yellow but the white wire to the rear ignition coil proved to be a better signal.
Small by -Ransome-, on Flickr
~Jacob
SICK50 Build Thread
BULLDOG Build Thread
Jacobus is offline   Reply With Quote
Old 21-03-18, 02:29 PM   #2
R1ffR4ff
R1ffR4ff's Avatar
Default Re: Jumpy tachometer solution.
Nice work and good to know
Any chance you could make a blow-by-blow of how you fitted and wired it just in case I ever need to replace my own on my Curvy?
Old 22-03-18, 02:00 AM   #3
Jacobus
Jacobus's Avatar
Sure ill try to do that this weekend.
One more tip I forgot to mention, if you get the cheap resistor pack from Amazon or ebay, be sure to meter each resistor. some of mine were a dead short.
~Jacob
SICK50 Build Thread
Old 22-03-18, 09:38 AM   #4
R1ffR4ff
R1ffR4ff's Avatar
Good stuff
Tachometer drift Terry Lee SV Talk, Tuning & Tweaking 13 30-07-15 02:38 PM
Tachometer dial template beabert SV Talk, Tuning & Tweaking 0 27-07-11 09:59 PM
Tachometer is down after CDI and battery died Cash SV Talk, Tuning & Tweaking 1 27-08-09 07:20 PM
Tachometer problem Roorkee SV Talk, Tuning & Tweaking 0 25-07-07 06:20 AM
Jumpy tach, possible fix dnwhoop02 SV Talk, Tuning & Tweaking 2 11-04-05 08:06 PM
