Old 30-01-08, 09:14 AM   #1
Curtis
Question Do I need to adjust air fuel mix on 05 sv650?
I have a 2005 sv650s stock standard. I am about to fit a yoshi slip on exhaust pipe and a K&N air filter to improve sound and a little hp. I believe the 03 - 05 sv has fuel injection, I have only seen advice for 99 - 03 sv's on air/fuel mixture when adding these modifications. Does anyone have advice for me on whether my air fuel mixture has to be adjusted and how?
Old 30-01-08, 01:11 PM   #2
John 675
Talking Re: Do I need to adjust air fuel mix on 05 sv650?
ive done the same with a carbon stubby and a K&N, im getting mine dyno'd but ive just purchased a power comander PCIII so im getting it all mapped in so i can change the map if i need to, i doubt you will see much performance increase whilst your on the stock settings, but id get it tuned to the after market parts you have installed
Old 30-01-08, 01:47 PM   #3
Curtis
Default Re: Do I need to adjust air fuel mix on 05 sv650?
Is the power comander PCIII a management system installed on the bike to remap the air/fuel ratio? (sorry its a newby question but I am new to this). Is it essential if you add a filter and slip on pipe? (as I dont want the bike to run too lean) How much did it set you back? I might want one!
Old 30-01-08, 02:00 PM   #4
Alpinestarhero
The power commander is an aftermarket device, which enables some tuning / tweaking of the otherwise mostly untweakable stock fuel injection system. Generally, a slip-on will not affect the fueling too much, although its a differant story with a full aftermarket system
See how the bike goes first before worrying about the fueling
Matt
Old 30-01-08, 02:11 PM   #5
Curtis
Thanks Matt.
I'll be sure to add a pic of mine to my profile soon.
I quite like the top box you've got, its one of the add ons i plan to do as my girlfriend complains about the back pack on long trips as a passenger.
Old 30-01-08, 05:11 PM   #6
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
....mostly untweakable stock fuel injection system....
you sure about that?
i was under the impression that steve jordans have the kit to remap the stock ecu to suit whatever can you have
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 30-01-08, 05:22 PM   #7
fizzwheel
fizzwheel's Avatar
Aye me to. I think and I might be wrong but this is what the Yoshi box does. I think a power commander does the same thing but gives your more options but it costs a lot more.
Old 30-01-08, 05:39 PM   #8
TEKA mapping changes the stock ECU maps, allows some adjustment, enough to sort out can and filter anyway.
PC3 is way more adjustable for other things than fuelling and you can also mess around with it via a computer, which is cool.
Fuel Range SV650 K6 SAMMY650 Bikes - Talk & Issues 20 24-05-08 11:59 AM
SV650 99 - 02 Fuel Tap Johnny Diablo Stuff Wanted 0 15-05-07 09:40 PM
Low Fuel Sensor For A K3 SV650 Brucey Stuff Wanted 0 13-04-07 04:19 PM
Fuel cap? Sv650 curvy Bikerz SV Talk, Tuning & Tweaking 6 11-06-05 04:17 PM
SV650 Valve Clearances - how easy to adjust? bsam20 SV Talk, Tuning & Tweaking 13 09-11-04 08:52 AM
