28-01-10, 01:36 PM | #31 |
Re: Smoking
Yea but you can go suck my single sided swing arm....bbadger 1 druid 0
Havent a clue tbh but ive been ebay hunting for a system already. btw stupid question but how do you get the seat off? |
28-01-10, 02:19 PM | #32 | |||
Re: Smoking
Honda, even Ducati had to go back to a double sided swingarm for racing. Double is better for everything apart from endurance and showing off. Quote:
Druid
'00 SV700S - '94 RVF400R - '97 RVF400R - '88 VFR750F |
28-01-10, 07:12 PM | #33 |
Re: Smoking
ahhhh thats what that lever does ....o the shame =[
well ill have you know it still looks good. i also have the another card to play but its a secret. Erm wouldnt say rusted but dffinatly dulled...looks like my front sv downpipe but abit grubbyer...still needs a clean once ive got the fairing off as there just what looks like salt crystals the size of marbles and gunk everwhere. |
30-01-10, 06:08 PM | #34 |
Re: Smoking
Update:
- Brakes sorted thanks to ian helping me out, and general problem solving. - Bike now stripped abit more than the photo. problems: - rad fubar but i have sussed replacement already - temp sender works when earthed but somthing is still a miss so need investigating, im feeling thermostat may be duf aswell. although the radiator is leeking so this probly isnt helping my problem. everything else seems sound just needs alot of tlc and paint. Last edited by BBadger; 30-01-10 at 06:31 PM. |
30-01-10, 06:29 PM | #35 |
Re: Smoking
Those down pipes look original
Not unheard of for the water pump to go, test is to pop the cap off and rev it, you should see the level fall and rise. If you just get vibration ripples chances are the pump is shot. Druid
30-01-10, 06:38 PM | #36 |
Re: Smoking
I keep forgeting the simple things to look for.
Tomorrow will be another day of investigation in that case so scraping any plans of a ride! |
03-02-10, 05:10 PM | #37 |
Re: Smoking
Druid ...any idea of which rads will fit the rc36 or pureply just rc36 modle specific ones?
03-02-10, 05:12 PM | #38 |
Re: Smoking
Well lots can be made to fit but its pretty specific.
Where is it leaking from? Druid
03-02-10, 05:23 PM | #39 |
Re: Smoking
Dam just as i though.
bottom leak i feel/ think. ive got another one its just i have the chance to send it back as one of the radiator fan brackets is broken. although the people who are going to pray it up for me can swap em over as the other rad has all brackets nicely intact. |
03-02-10, 05:26 PM | #40 |
Re: Smoking
I've had good results on fixing leaks with plastic padding stop-leak, doesn't work too well on fins but works a treat on the sides. Not pretty but effective.
If you have access to one you could tig it. http://www.pvdwiki.com/index.php?tit...adiator_Repair Druid
