Idle Banter For non SV and non bike related chat (and the odd bit of humour - but if any post isn't suitable it'll get deleted real quick). There's also a "U" rating so please respect this. Newbies can also say "hello" here too. |
24-12-12, 11:38 AM | #31 |
Re: Windows 8 for £25?
If speed's important to you then yes its a decent upgrade. You'll live with or or ignore the tiles and a normal desktop is available. Search for anything using the windows button and typing in, so similar function to the start button. But what works best for me is being able to start working on anything using any program, shut the lid and it will save my work while keeping the laptop in the equivalent of hibernation. But lift the lid and start up is instant. There's no need to save anything or power up/down. Bad things are as mentioned above.
24-12-12, 12:49 PM | #32 |
Do this quick. It wont be free next year. Get your key in an email.
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ), drop it & fix it again! K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
24-12-12, 01:15 PM | #33 |
Windows 7 | the_lone_wolf | Idle Banter | 45 | 25-10-09 11:31 AM |
windows 7 | blueto | Idle Banter | 13 | 20-09-09 06:42 PM |
Windows XP 32 or 64 bit? | Caddy2000 | Idle Banter | 8 | 26-08-08 12:03 PM |
Windows 7 | gettin2dizzy | Idle Banter | 15 | 09-04-08 12:27 PM |
New Windows | Law | Idle Banter | 61 | 01-02-07 11:53 PM |
