20-03-08, 06:00 PM | #1 |
Captain Awesome
Not the usual braided hose thread
simple question, it's actually for the DRZ but it's applicable to all hoses - i have my goodridge lines all ready to go, but where you screw in the banjos, would it be wise to use PTFE tape or similar to create a good seal? or should they just be screwed in tight?
Official "Dumbass of the Year" 2011 (•_•) ( •_•)>⌐■-■ (⌐■_■) Deal with it... |
20-03-08, 06:06 PM | #2 |
Re: Not the usual braided hose thread
Just screw them in tight, never had a problem with either HEL or Goodridge banjos before and I have lost count of how many braided hoses I have fitted to various bikes!
20-03-08, 06:15 PM | #3 |
Captain Awesome
cheers, just wanted to make sure
roll on saturday, when i try to bleed them
20-03-08, 06:54 PM | #4 |
nah, you should not use any tape. You obviously need plenty of copper washers though. You understand that you need a copper washer at each mating surface?
So for the calipers it would be caliper-copper-banjo-copper-bolt, and at the master cylinder depends on the type of bolt you bought and the number of lines. |
20-03-08, 07:15 PM | #5 | |
Captain Awesome
where does one obtain these copper washers? will any the right size do or are there specific brake caliper washers? also, is it obvious that i've not done this before?...
20-03-08, 07:20 PM | #6 | |
The washers seal the joints by being squashed slightly as you tighten everything up. Older ones have already been squashed once (or more times) before so can be risky to re-use. Forgot to mention, these washers are intended for motorcycle brake lines, dont go using any old tap washers from B&Q |
20-03-08, 07:22 PM | #7 | |
Captain Awesome
thanks for the warning, anything else a first timer should know?
20-03-08, 07:40 PM | #8 | |
The front brakes are your best friend and not something you want to bodge. |
20-03-08, 08:39 PM | #9 |
Captain Awesome
hence why i'm taking it to a friend who does know what he's doing, i'll be doing the work but he's going to give advice, it's about as simple as it gets anyway, one line, one calliper. it's not going to be bodged...
20-03-08, 08:45 PM | #10 |
Shouldn't need tape as the threads aren't meant to seal, it's the washers that do it.
I reuse the old washers and keep my eye on them for leakage, I know I shouldn't but haven't had any problems yet
Goodridge Braided Hose Sets | SV-net | SV Talk, Tuning & Tweaking | 15 | 25-07-08 11:29 PM |
not the usual tool thread | timwilky | Idle Banter | 2 | 26-02-08 06:29 PM |
braided hose banjo bolt question | Marksv | SV Talk, Tuning & Tweaking | 2 | 25-08-07 08:36 PM |
K&N air filter, light blue seat cowl, rear braided hose, and end can | unlucky biker | Stuff Wanted | 4 | 25-04-07 05:55 PM |
Another braided hose question | rob13 | SV Talk, Tuning & Tweaking | 4 | 24-02-07 11:00 AM |
