07-06-05, 08:01 AM | #1 |
Fuel Injection problem???
Every now and then I will switch my 04 bike on and it wont make its usual computer whiiiiiiiirrrrrrrr sound and then it flashes up FI at me. I then turn it off, wait a few seconds and turn it back on (sometimes I have to do this many times!!)
Is this a common thing? Is my fuel injection stuffed or just being a pain? Hope someone can help |
07-06-05, 08:18 AM | #2 |
Check the connections in your kill switch - this sounds the most likely. However, if you've never had it cut out on you while riding then it's a long shot.
Alternatively, there could be a gear position sensor problem - the bike things you're in something other than neutral, and the side-stand is down. However, the easiest solution is - take it to the dealer - it's still under warranty!
SV650 K3 - Gone. Now a member of the SV650.org Kawasaki brigade! |
07-06-05, 08:56 AM | #3 |
It's an '04 bike, ring the garage up & tell 'em, it's under warranty
07-06-05, 09:01 AM | #4 |
Tried the kill switch but that is fine. Also looked at the switch from the stand etc but I cant find anything there.
Good point about the warranty cloggsy! Just wondered if anyone had had the same random thing?? |
07-06-05, 09:16 AM | #5 |
My K3 does this its the anti hot wire contacts in the ignition switch try some WD40 or simuliar in your switch or wriggle the key whilst turning it.
07-06-05, 09:56 AM | #6 |
Have you changed anything on the bike, added something or had something apart?.
Id take it down to a dealer who should be able to get the fault code up and then let you know whats causing the problem. Rather than 2nd guessing its best to know for sure. |
08-06-05, 12:21 AM | #7 |
on my tlr it wont do it if you turn the key when its in gear..when you pop it into neutral it does the whirring noise then,
Fuel Injection Light | mayang | SV Talk, Tuning & Tweaking | 0 | 24-07-06 07:23 PM |
fuel injection issue | w1ll15 | SV Talk, Tuning & Tweaking | 5 | 18-07-06 05:02 PM |
K6 Fuel injection | Baph | SV Talk, Tuning & Tweaking | 4 | 12-07-06 10:41 AM |
Fuel injection in winter | Mariska | SV Talk, Tuning & Tweaking | 15 | 27-03-05 04:40 PM |
Fuel Injection... | steveo | SV Talk, Tuning & Tweaking | 6 | 23-11-04 01:43 PM |
