Old 06-05-06, 04:07 PM   #1
Bez
Default Fuel Light Problem
Anyone have any ideas on this problem.
The fuel light on my bike (2004 pointy) flashes constantly even when the tank is full. I was thinking fuel sender unit but it stays flashing even when the fuel pump / sender unit multi plug is disconnected. Everything else works perfectly on the clocks.
Old 06-05-06, 04:10 PM   #2
svrash
I think the sensors work by floats, if thats the case then the float could be stuck
If the light flashes when the connection is broken, maybe the connection is broken elsewhere
Old 06-05-06, 05:06 PM   #3
Yarodia
P O I N T L E S S T H R E A D A L E R T
Is it connected to your indicators?
Old 06-05-06, 05:52 PM   #4
Bez
Dont understand your pointless reply mate. ???
Old 06-05-06, 05:54 PM   #5
Bez
I am thinking that the fault might be in the clocks. Am i right in thinking when the fuel gets low the sender sends power to the clocks and the warning light comes on
Old 07-05-06, 04:41 AM   #6
Yarodia
My mistake, I wasn't refering to your thread. Should have said pointless post, I was just makin a joke
Old 07-05-06, 05:30 AM   #7
tigersaw
tigersaw's Avatar
Any idea what happens when the fuel gets low for real, i.e. when it should change from flashing to constant on?
If its a 2004 bike isn't it a warrentee issue?
Old 07-05-06, 02:39 PM   #8
tinpants
Ubique
tinpants's Avatar
Does it affect the tacho and / or speedo?? I had a similar problem with my curvy and it turned out to be defective clocks. HTH.
Jesus loves you. Everyone else thinks you're a pillock
tinpants is offline   Reply With Quote
Old 08-05-06, 01:04 PM   #9
Bez
Thanks for the replies. I gave everything a good check today with the multimeter. The fuel sensor works perfect and the wiring up to the clocks/speedo multiplug all checks out, so it does look as if it is shorting out inside the clocks.
I bought the bike slightly damaged and it is a bit altered from standard now. I think they would laugh if i asked a dealer to get it fixed under warranty.
To sort it i'll put a bit of tape over the constantly flashing fuel light and place an LED next to the clocks and run it into the existing wiring.
Next problem? Fuel light and meter needles thedonal SV Talk, Tuning & Tweaking 34 19-12-08 10:47 AM
fuel light v-twin luke SV Talk, Tuning & Tweaking 4 19-10-07 09:38 PM
gas light?(that'll be fuel warning light) Spanish Fly SV Talk, Tuning & Tweaking 9 08-06-07 05:45 PM
Replacement fuel light / fuel tap riktherider SV Talk, Tuning & Tweaking 7 14-05-07 06:41 PM
fuel light jonhunt Bikes - Talk & Issues 8 25-08-05 07:05 PM
