Old 30-07-20, 06:44 PM   #7251
Kenzie
Kenzie's Avatar
I know right. Also, the Outlet SRT303 works fine. Got a dent in the prism hump but a small bit of wood after taking the top plate off has solved that, just a ripple instead of a dent.
Oh, the serial number on the lens falls between the serial number range for 1937/1938
Old 30-07-20, 07:22 PM   #7252
Kenzie
Kenzie's Avatar
Bargain basement 303
Sent from my Xperia using Tapatalk
Old 30-07-20, 07:54 PM   #7253
yokohama
Nice bit of history to the Contax. And the 303 is the best of the SRT range. You've done well.
Old 30-07-20, 07:56 PM   #7254
Kenzie
Kenzie's Avatar
I was actually going to swipe the prism for the XE1 but the cds cells are glued to the prism. Reused the lens you sent me so all is good. Shame I can't price the history, but it's pretty compelling.
Old 02-08-20, 10:40 AM   #7255
Kenzie
Kenzie's Avatar
Shot from my Kodak Pocket No.1 Folder. Taken at Beeston Regis Beach during our camping trip a few weeks ago. Had to straighten it a little as my framing was off.
A few from the OM1 50mm f3.5 macro
Old 03-08-20, 08:07 PM   #7256
yokohama
Some nice macro shots there. I discovered a set of Vivitar close up filters among all the discarded bits and bobs I have but they are 55mm!! Nothing fits. I need to look for a step down ring.
The Spotmatic is proving a disaster. After taking a few shots using the centre needle metering, I actually glanced at the shutter and aperture settings to find it's way out. Working but not working. To make it worse, I keep forgetting to close the aperture down on the Helios after focussing. I'm not holding out much hope for the results,
Old 03-08-20, 08:44 PM   #7257
johnnyrod
johnnyrod's Avatar
As far as I know the circuits in the Spotmatics are fairly resistant to differing battery voltages. The one I have here works fine with 1.5V cells. Does yours (or the combo with the Helios) not have automatic diaphragm closure? Without getting it out again, I think the SP500 does. I guess you'll find out how much latitude your film has.
Old 03-08-20, 09:06 PM   #7258
yokohama
I think the metering needs fixing Johnny. The needle moves and responds to changing light but it's not accurate. The battery is new and battery check shows it as fine. I've tried changing the ASA to get the exposure correct but then, the needle goes all over the place.
The Helios is the 44-2, a weird one. It's got 2 rings. One to set the aperture; the other opens the aperture fully to focus but needs closing down again before taking the photo, which is the bit I keep forgetting.
Old 04-08-20, 07:06 PM   #7259
johnnyrod
johnnyrod's Avatar
Ah I see, I have a 450mm f8 like that. So yeah, it's non-auto.
Old 05-08-20, 09:06 PM   #7260
Kenzie
Kenzie's Avatar
Don't know whats up with my notifications, but I haven't had any for the replies for the last two days.
