Old 12-11-16, 04:47 PM   #1
SheepShagger
Default Rear sprocket, speed sensor and skimmed gen1 rear brake hanger
Hi guys, these bits are surplus to requirements on my build.
First is a 45T rear sprocket, this looks totally unused and camw on a rear sprocket carrier i bought.
£10
Second is a speed senaor off a pointy as i was going to go with pointy clocks. I now have KOSO GPS clocks to go on so this is now surplus. In perfect condition with rotor.
£20
Lastly is a curvy rear caliper bracket, this was profesionally milled down 5mm to allow you to run the speed sensor on the rear wheel in place of the right spacer. This is great if you're doing a front end swap.
£20
Sent from my SM-G935F using Tapatalk
SheepShagger is offline   Reply With Quote
Old 21-11-16, 10:26 AM   #2
SheepShagger
Default Re: Rear sprocket, speed sensor and skimmed gen1 rear brake hanger
Sprocket sold
Curvy rear brake disc, sprocket and sprocket carrier Bunkle Stuff Wanted 2 05-04-14 10:08 AM
(k4) Rear brake lever & Speedo sensor kaimera Stuff Wanted 1 26-06-11 03:06 PM
curvy rear brake caliper bracket / hanger fastdruid Stuff Wanted 0 21-02-10 09:50 PM
Think I've warped my rear disc! Can they be skimmed? monkey Bikes - Talk & Issues 5 03-03-08 10:31 PM
Rear brake like sensor rwoodcock01 SV Talk, Tuning & Tweaking 2 10-06-07 12:12 PM
