Old 02-04-07, 08:59 PM   #1
StreetHawk
Default Connecting a trickle charger to my SV..
My bike is not being used at the mo due to not having a license for at least 2 weeks until I take my test
It's got a Datatool alarm on it so i'd like to connect a trickle charger, i've heard they can drain the batt easily if the bikes not being ridden. Is there a connector that I can plug staight into?
Old 02-04-07, 09:10 PM   #2
Ed
Default Re: Connecting a trickle charger to my SV..
Nossir not unless you fit one - get one to fit your charger. You'll have to put your Datatool into service mode and then fit the gizmo, very simple (although I needed John to help me ). I don't understand why his draws next to no current and yet mine kills the battery after just a few days. Must be this crap British engineering
Old 02-04-07, 09:12 PM   #3
StreetHawk
Cheers Ed, I haven't got a charger yet, which one do you use?
Old 02-04-07, 09:15 PM   #4
Ed
An Optimate 3. It came free if I had a Datatool fitted to my SV. It is very very very good.
Old 02-04-07, 09:17 PM   #5
fizzwheel
fizzwheel's Avatar
Another vote for the optimate, We're in the same position I can leave the GSXR for a good couple of months without the battery going flat, and my SV to, both are alarmed, however the batter on Liz's Duke, goes flat after a week or so.
Oxford do a version called an "Oximiser" works the same way and I think its a few quid cheaper...
Old 02-04-07, 09:34 PM   #6
no problems with my optimate in the last 3 years, good piece of kit.
Old 02-04-07, 09:41 PM   #7
StreetHawk
Optimate it is then! Sounds like just what I need. Do I attach the round connectors to the battery and then it's just a case of plugging in and out of the white connector when I want to charge?
Old 02-04-07, 09:45 PM   #8
yep thats it, just hang the white plug in connector down where you can get to it to same keep removing the seat.
Old 02-04-07, 09:46 PM   #9
http://www.infinitymotorcycles.com/p...?ProductID=876
i paid about £40 for mine.
Old 02-04-07, 09:56 PM   #10
StreetHawk
Cheers! I'll get the hang of all this soon and quit the questions!
Solar Powered trickle charger fatneck Bikes - Talk & Issues 14 26-11-08 01:10 PM
Connecting sleeve for original pipe Cyclops Stuff Wanted 3 25-09-07 11:24 PM
Wanted: K3 Engine or Crankcase or Connecting Rod dmccue Stuff Wanted 2 14-06-06 09:18 AM
Connecting pipe leaks ***Steve*** SV Talk, Tuning & Tweaking 6 05-05-06 06:54 PM
Do solar powered trickle chargers work??? svrash Bikes - Talk & Issues 9 13-03-06 11:42 PM
