05-04-17, 05:20 AM | #1 |
Indicator wire terminal connector thingy
Hi guys,
Sorry for the technical title, not sure what it's actually called, but I'm after the connection bit for the 2 indicator wires that sit in the relay holder. Trying to revert it back to standard after someone bodged it badly to fit leds. The brown and light blue wires if that helps. They pulled the wires out and cut connectors off, and I want to use the standard 7 pin relay. Many thanks. Andy |
05-04-17, 08:11 AM | #2 |
Re: Indicator wire terminal connector thingy
This is me assuming they're not just regular spade connectors pushed into the holes?
If someone could tell me what they're called I can go and buy some? Thanks Andy |
06-04-17, 06:31 AM | #3 |
What bike? may help you get some replies
Black naked 1999 sv650 which im trying to keep happy Custom paintwork Saragon Customs Spray painting Electrical fault finding guide and Regulator rectifier test Only a biker knows why a dog sticks his head out of a car window. |
06-04-17, 06:47 AM | #4 |
If its for a pointy? then this thread (click me) on svrider has a picture of connector ends and this company (click me) in Scotland do all kinds of bits so might be worth a look? HTH until the clever more helpful peeps come along
08-04-17, 05:42 AM | #5 |
Thanks buddy, been off with work last couple days, managed to raid their workshop and find something off a volvo truck that fit the bill perfectly. It now flashes properly
loose indicator wire SV650 sk6 | scotty217 | SV Talk, Tuning & Tweaking | 6 | 16-02-16 09:54 PM |
Pointy Rear Master Cylinder connector thingy - Wanted | Redmist | Stuff Wanted | 5 | 16-07-15 05:59 PM |
Rear brake pedal screw piece thingy connector | ManMango | Stuff Wanted | 3 | 18-09-14 07:11 PM |
Carby S indicator signal wire | hardhat_harry | SV Talk, Tuning & Tweaking | 2 | 07-02-12 04:12 PM |
how to wire indicator resistors? | roadrunneruk | SV Talk, Tuning & Tweaking | 8 | 24-10-09 08:45 PM |
