Old 08-03-19, 08:47 AM   #6091
Kenzie
Kenzie's Avatar
Blimey you were up early! Yes its the Jupiter 8m.
Sent from my Xperia using Tapatalk
Old 08-03-19, 09:11 AM   #6092
johnnyrod
johnnyrod's Avatar
I got good results with both Jupiter 8 and Sonnar 50mm f2 (basically the same) on my Kiev. Much more like a "modern" SLR lens than a Tessar.
Old 08-03-19, 09:30 AM   #6093
Kenzie
Kenzie's Avatar
I think I solved the light leak issue on the Kiev 88. Its coming in through the dark slide slot. Needs new light seals. Shot from the taped up 88.
Old 08-03-19, 12:46 PM   #6094
johnnyrod
johnnyrod's Avatar
Looks nice. My Box Tengor came yesterday, pretty good, I can put a film straight in it. Also came with a grubby Brownie and an old Instamatic 155 like my old mam used to have, nasty piece of junk but clean and working. The Tengor has a lot of features for a box camera (it's the last one Zeiss did) - cable release socket, flash sync, tripod socket, double exposure lock, three distance ranges (by adding in lenses inside) and three apertures from f9 to f22 (stops that swing into place). By allowing a wider aperture, the distance settings are necessary as the DoF is smaller. I think they're something like 6-20ft, 10-40 and 20-infinity, and not sure which aperture they refer to.
Old 08-03-19, 07:23 PM   #6095
Kenzie
Kenzie's Avatar
I wouldn't mind a Zeiss Box but they keep jumping out of my reach. But then again I've got quite a few box type cameras. I've got more film to scan as I had sent off the 88 and Perkeo films.
Old 09-03-19, 07:03 PM   #6096
Kenzie
Kenzie's Avatar
A few more from the 88
It performs well when it doesn't leak!
Voigtlander Perkeo:
Got an OM1 body listed, I would have included a lens but I haven't got on that hasn't got some sort of defect. I did find a Balda Baldina rangefinder at the re-use shop for a fiver. I checked the Prakticas and they had an LTL3 up there.
Old 09-03-19, 09:04 PM   #6097
johnnyrod
johnnyrod's Avatar
Nice pics
Old 09-03-19, 10:09 PM   #6098
admin
John T
admin's Avatar
Nice subtle colours.
Sent from my Moto G (5) using Tapatalk
Old 10-03-19, 11:42 AM   #6099
yokohama
Really good images from the 88.
Old 10-03-19, 11:44 AM   #6100
Kenzie
Kenzie's Avatar
Cheers all. I might list one of the Canon Sureshot A1 cameras (I have three) as they seem to be selling well at the moment. Now if I only had the plates for mine!303055284591
