Old 24-09-19, 06:16 PM   #1
gadget
Default Alternative balancing tool !
After reading /studying the many posts on tuning / balancing carbs, I have the chance to borrow one of the 'snail' type carb air flow gizmo's, the type that has a conical end that can be pushed into the 'trumpet' /inlet when motor is running and then the scale on the meter can be read at a glance. (I have seen these being used on webber 40's sidedrafts etc on cars)
So ... just wondered if anyone has tried this method of balancing on the sv ?
I can't see why it wouldn't be as effective as a manometer or traditional gauges.
It would certainly be a whole lot quicker and easier to do it this way that's for sure.
Anyone have any views / first hand experience or pro's 'n' cons' of doing it this way?
gadget is offline   Reply With Quote
Old 24-09-19, 08:19 PM   #2
johnnyrod
johnnyrod's Avatar
Default Re: Alternative balancing tool !
I did a quick google and if it's the sort I'm thinking of then it measures air flow in not vacuum pressure after the butterfly. The point of balancing the carbs is so the slides lift together which is down to equal vacuums that then draw the air out of the chamber above the diaphragm, so while airflow is related, I doubt it'd be accurate enough. Also the airflow at tickover is quite small.
Old 25-09-19, 05:04 PM   #3
gadget
Aha, good point, didn't think of that.
Many thanks for the info, I may have been messing with that tool all day and getting false readings and probably doing more harm than good.
Cheers.
Old 26-09-19, 09:17 AM   #4
R1ffR4ff
R1ffR4ff's Avatar
Cheers.
This may be of interest to you,
https://cx500.000webhostapp.com/SV650Carb_Balance.html
HTH
Old 10-10-19, 04:08 PM   #5
gadget
Thumbs up Re: Alternative balancing tool !
Thanks for the link, saw those in a magazine while back. Mine does seem a little lumpy at idle and I am experiencing some numb digits after about half hour of riding. Think I'm just going to have to invest in a balancing tool of some description. Probably the carbtune, looks like a doddle to use. Cheers again for info.
Old 10-10-19, 07:39 PM   #6
johnnyrod
johnnyrod's Avatar
Personally I prefer a pair of Davida Gauges. Don't buy cheap ones. You can use a pair to balance any number of cylinders.
Old 10-10-19, 07:52 PM   #7
glang
The big disadvantage of using a flow meter is that it measures just one carb/throttle body at a time and as it works by creating a slight restriction affects the tickover. So in swopping it between the measurements youve introduced a small variable that creates inaccuracy which on a car is insignificant but on a bike more important.
You can balance the carbs very accurately without expenditure by using a home made manometer. You just need a long length of plastic tube and some water....
Old 04-11-19, 05:51 PM   #8
gadget
I have eventually decided to put it in the capable hands of a mechanic mainly because I have absolutely nowhere to do the work and don't fancy getting cold n wet doing it out in the road. So .... fork out some hard earned and hopefully it'll all be sorted.
Spark Plug Removal Tool/Tool kit Question zombie SV Talk, Tuning & Tweaking 4 17-02-14 02:09 PM
Rock balancing Berlin Photos 10 20-07-11 10:07 AM
SV Tool Kit/Spark Plug tool svdemon Stuff Wanted 1 17-12-07 12:29 PM
What else do I need other than a carb balancing tool?(pics) SpankyHam SV Talk, Tuning & Tweaking 13 08-08-06 09:29 AM
Balancing your carbs Sir Trev SV Talk, Tuning & Tweaking 11 08-08-05 08:35 PM
