Old 06-10-19, 09:39 AM   #1
Seeker
Seeker's Avatar
Default SV650X on a dyno
https://www.youtube.com/watch?v=jTm6URsJwKQ
...makes more power in 5th gear than 6th gear.
2016 SV650AL7
2023 GSX-8S
Old 06-10-19, 09:59 AM   #2
Craig380
Default Re: SV650X on a dyno
That's really interesting, but what got me is the significant difference between 4th and 5th gears. I wonder why
Suzuki mapped the ECU for more power in 5th than 4th? Emissions and noise testing? 3.5bhp difference at 8,000rpm is quite a lot.
The differences between 5th and 6th are 0.5bhp max, which probably falls into the area of experimental error - the dyno guy points out that the shape of the 5th & 6th gear curves are very similar.
The baseline run with the bike as standard matches the results of pretty much every other dyno test I've seen on the Gen 3 bikes: around 71bhp and early 40s ft-lb of torque.
Old 06-10-19, 10:41 AM   #3
embee
embee's Avatar
You need to understand the fundamental principles and experimental error factors involved in testing. Inertia dynos without controlled conditions aren't particularly accurate/reliable/repeatable.
In order to determine engine power for certification/homologation purposes it must be done at steady state for a minimum period of time with all the environmental parameters held essentially constant. That means absorption dynamometers with temperature control for a start. These are expensive/complex, hence the use of inertia dynos by most "shops".
Running in different gears operates the dyno over different speed ranges for a start, never mind any effects within the power unit. Taking results from the dyno using different "road" speeds isn't going to give necessarily particularly comparable results.
How repeatable/accurate is the dyno anyway? It relies on measuring the acceleration of the rollers and calculating the input power based on the inertia and instantaneous speed. The bike is accelerating the wheel as well as the dyno, if the dyno calcs don't take the wheel into account the effect of being in different gears will change the result. The rolling resistance will also change with speed for both the dyno rollers themselves and the tyre/roller contact.
Lots of factors.
Inertia dynos are useful for assessment but +/-3% uncertainty is probably fairly good going, +/-5% wouldn't be unusual.
Old 06-10-19, 10:41 AM   #4
Seeker
Seeker's Avatar
In part 4, they fit a 180 section rear tyre which "transforms" the handling. The new SV uses a 5 inch rim which means the standard 160 section tyre doesn't fit that well.
https://www.youtube.com/watch?v=hcYyJVASJVA
In part 5 (not yet posted) the bike will have a new exhaust, power commander and quick shifter and will be back on the dyno.
2016 SV650AL7
2023 GSX-8S
Old 06-10-19, 10:56 AM   #5
Craig380
Completely agree, but it's interesting that there's such a difference between the 4th & 5th gear runs, but only minimal differences between the 5th & 6th gear runs. As the runs were done back-to-back, I'm not sure the differences can be all be explained by the margins for error.
Sv650x Seeker SV Talk, Tuning & Tweaking 7 26-09-17 06:03 PM
sv650x ecu sa 71 Stuff Wanted 13 15-05-13 11:05 AM
Reg / Rec for sv650x ('99) Terah Stuff Wanted 2 03-07-11 07:55 PM
What does the X mean in SV650X wow Bikes - Talk & Issues 4 04-03-08 12:55 PM
SV650X 99 Curvy cottonbud Stuff Wanted 0 04-10-06 07:35 PM
