Old 10-09-08, 11:37 AM   #1
AndyBrad
Default running rough this morning
Ok so started the bike up this morning fine. Put a little bit of choke on it then procedded to get my kit on. Pushed it around the front then it cut out. Tried getting it going and it took about 4-5 goes with the starter to start. A bit of spluttering and it sounded rough. Had to keep the throttle open to keep it tiking over. Once it was warm it seemed fine but took about 5 mins to egt going.
Any ideas whats up?
Old 10-09-08, 11:42 AM   #2
thedonal
Default Re: running rough this morning
It's getting colder out?
I do notice as well that my bike is a bit more/less vibey in different weather conditions (ie high/low pressure)
Old 10-09-08, 11:43 AM   #3
Grinch
Probably left the choke on to long and you might have got a little moisture in with your mix. Was it a touch cold and damp this morning in your area?
Old 10-09-08, 11:44 AM   #4
vardypeeps
Yeah mine was a bit rough this morning as well had to try two times to start it and put a bit of throttle on to get it going before I put the choke on. after that it was fine.
Old 10-09-08, 11:46 AM   #5
vardypeeps
Heavy rain through the night and a chilly start. There won't be anything wrong with it matey. See if it does it again later today as it's nice and warm outside now
Old 10-09-08, 11:51 AM   #6
also if you go on short journeys a lot in this kinda weather, that has a bearing on your start up. SVs don't like short damp runs at all. I have learned a large lesson from doing this over the years on my two
Rough running and noise. arcdef SV Talk, Tuning & Tweaking 31 25-03-09 08:57 PM
rough running ? mikey devon SV Talk, Tuning & Tweaking 11 21-03-09 12:07 AM
Running rough when hot svdemon SV Talk, Tuning & Tweaking 3 13-08-08 07:44 PM
Running rough, running out of ideas. Sarj SV Talk, Tuning & Tweaking 17 04-12-07 06:45 PM
Running Rough? mike_b SV Talk, Tuning & Tweaking 3 20-12-06 11:38 PM
