Old 18-04-11, 07:02 AM   #1
Stuuk1
Stuuk1's Avatar
Default Cleaning of the chain?
Is it so bad to get the pressure washer out and blast the hell out of it, let it dry and then re-grease it?
RIP Reeder 20/07/1988 - 21/03/2012
Stuuk1 is offline   Reply With Quote
Old 18-04-11, 08:07 AM   #2
missyburd
Default Re: Cleaning of the chain...
don't be lazy, get stuck in with paraffin and a toothbrush
Old 18-04-11, 08:43 AM   #3
AndyBrad
what she says.
although if your lazy. i have had very good results with muc off chain cleaner and just as good as parafin results with muc off DRY chain cleaner.
clean it on somone elses driveway tho
Old 18-04-11, 08:47 AM   #4
G
A pressure washer risks blasting water into the seals, at least that is my understanding.
I just use a big paintbrush and old towel with a chain cleaning substance, take 5 minutes.
6.67300 × 10-11 m3 kg-1 s-2
Old 18-04-11, 08:48 AM   #5
If you've no toothbrushes going spare or parrafin, WD40 a rag and elbow grease does just as well.
Old 18-04-11, 09:13 AM   #6
Dicky Ticker
Any light oil you may have about,diesel,lamp oil paraffin,just as long as it is an oil.This keeps the seals lubricated and allows better penetration of whichever chain lub you use.My preference is to re-lub a second time after a short ride while the chain is hot.
I would only pressure wash a chain if it was off the bike and could be soaked in an oil bath before refitting
Old 18-04-11, 09:17 AM   #7
Amplimator
Paraffin is way cheaper than any chain cleaner but just as good and re-useable. Fill a large coffee jar with the stuff, clean your chain with a large denture type toothbrush and put the lid on the jar when your finished. All the gunk will settle at the bottom so you can use again on the next clean. Dispose (safely and sensibly of course) every X amount of cleans and refill. Lasts for donkeys.
Re-lube heavily after cleaning as it really gets rid of all the old gunky lube leaving a clean but dry chain.
I find chain cleaning almost therapeutic (sp?) but then im kinda sad like that.
Old 18-04-11, 11:23 AM   #8
thedonal
Originally Posted by AndyBrad View Post
what she says.
Or just put some newspaper down under the chain?
The Muc-Off dry chain cleaner is really good.
Old 18-04-11, 11:32 AM   #9
husky03
husky03's Avatar
we power wash the work bikes mate and to be honest the chains look worse than any i've seen-they get covered in wd40 afterwards then re lubed but still look like crap, if they don't get relubed everyday they start to squeek like hell and before you know it they end up with seized links and the chain banging off the sprocket cover on the downshift( but our bikes do get hammered rotten)-better to brush it with paraffin and lube it.
husky03 is offline   Reply With Quote
Old 18-04-11, 02:06 PM   #10
johnnyrod
johnnyrod's Avatar
Default Re: Cleaning of the chain?
Cleaning chain = waste of time
you'll be polishing the tyres next! Get out and ride it!
Chain cleaning rictus01 Bikes - Talk & Issues 37 14-04-09 11:08 PM
Cleaning chain...... jumjum_0214 SV Talk, Tuning & Tweaking 9 15-08-08 09:22 AM
Chain cleaning _Stretchie_ Idle Banter 12 26-04-06 02:16 PM
Cleaning chain JASONSCOTLAND Bikes - Talk & Issues 16 27-03-06 12:43 PM
Chain Cleaning alka SV Talk, Tuning & Tweaking 15 03-04-05 08:54 PM
