Old 10-11-14, 03:15 AM   #1
Sentinel
Default Valve adjustment how to?
My Gladius is almost due for the valve check/adjustment service. I have searched and skimmed through related threads here and elsewhere. I do have the Suzuki manual, and I also have the Haynes, but I'm also looking to see if there are any "How To" posts and or videos available online of a valve adjustment being performed on this engine.
I'm also looking for any tips or advice anyone has to offer.
Someone said I need and OBD tool to set the throttle bodies up afterwords. What's that all about?
I have done valve adjustments on less complicated engines with less complicated valve systems before. I've done the simple screw type and I've also done the shim "over" bucket type once before, which doesn't require removal of the cams, and is easier and less complicated than the shim under bucket setup on this bike. I've never done an adjustment on a V engine or any engine with "shim under bucket" adjusters before, so this will be my very first. The job looks straightforward enough, but if there's any more info, video, how to, hints, tips, or whatever I'd like to see them.
Old 11-11-14, 07:41 PM   #2
oldeboi
Junior Member
Default Re: Valve adjustment how to?
Not sure if this will help.....
http://www.bluepoof.com/motorcycles/howto/svs_valves/
oldeboi is offline   Reply With Quote
Old 12-11-14, 02:50 PM   #3
jambo
jambo's Avatar
That's a good guide. Only thing I'd add is that if you've disturbed the cams, make sure when you've put the cams and tensioners back in that you turn the motor over a few times by hand and double check the chain tension & timing before putting the covers back on, plugs in and thumbing the starter. Gives you an extra piece of mind that you've done it correctly before you apply force to everything.
Jambo
Old 23-11-14, 08:42 AM   #4
Sentinel
Thanks for the help guys.
Valve clearance adjustment pics curvy. 85jas SV Talk, Tuning & Tweaking 7 02-05-13 07:10 PM
Valve adjustment/cam timings - how difficult? daveyrach SV Talk, Tuning & Tweaking 22 16-02-13 08:49 AM
Valve adjustment - how? zinomori SV Talk, Tuning & Tweaking 2 07-11-10 01:56 AM
Valve adjustment - how much? lh25 SV Talk, Tuning & Tweaking 11 03-10-10 01:16 PM
Valve clearence adjustment Robssv SV Talk, Tuning & Tweaking 22 18-12-06 08:35 AM
