Old 05-05-07, 10:44 AM   #1
weazelz
Default where to get long gear shift rods?
I have bent my gear link shift rod thing rather badly & could do with a new one. problem is that it's for walter moto rearsets & is 190mm long, so a bit long for a bit of 4mm rod with threads on the end (if I even had reverse thread dies - or normal ones for that matter - or 4mm rod)
anyone know where I can get a long rod (fnar fnar)? 190mm would be ideal, or ~212mm would be okay too as I have a ~22m extension peice on because of the jack-up plates I have on too
thanks
Old 05-05-07, 03:52 PM   #2
John Burt
Default Re: where to get long gear shift rods?
Try a local engineering firm, don't forget left hand thread at one end; well or a mate with acces to a lathe.
Old 05-05-07, 04:34 PM   #3
Bandit 600's rod, IIRC, is very long. Fnarr, again.
Gear Shift Rod bent - Gear Changing problem Thaleshwar SV Talk, Tuning & Tweaking 13 05-06-10 06:28 PM
Gear shift rod Sean_C SV Talk, Tuning & Tweaking 3 21-02-09 08:04 PM
Gear Shift Lever? silent11 SV Talk, Tuning & Tweaking 20 02-07-08 09:06 AM
Gear shift lever dizzyblonde SV Talk, Tuning & Tweaking 5 07-05-08 09:16 PM
Reverse gear box shift lukemillar Bikes - Talk & Issues 7 08-05-07 09:17 AM
