Old 20-04-17, 07:28 AM   #3251
Kenzie
Kenzie's Avatar
To be honest I am so rubbish at soldering that I might not bother. There was some corrosion in the battery chamber anyway. If I did want to fix it then all I need to do is remove the front ring again.
Sent from my Xperia using Tapatalk
Old 20-04-17, 06:27 PM   #3252
Kenzie
Kenzie's Avatar
Rangefinder patch? No, that is optional as well. Popped the top off to reglue the rf mirror. I think it is about as good as it will get now.
Old 20-04-17, 06:59 PM   #3253
yokohama
No rangefinder patch? The lens has distance settings as back up I guess.
Did you get to try the X700?
Old 20-04-17, 07:13 PM   #3254
Kenzie
Kenzie's Avatar
The internal mirror fell off and was in the top plate. Spot of glue and its fine. Vertical alignment is off a bit but usable. Not had a chance to use the X700 but we are going away at the end of May so will take it then. I won the lens by the way Johnny.
https://frankencamera.wordpress.com
Old 20-04-17, 07:49 PM   #3255
johnnyrod
johnnyrod's Avatar
A good day then!
Old 20-04-17, 07:53 PM   #3256
Kenzie
Kenzie's Avatar
Yeah, might have to find another Praktica body to put it on.
Old 20-04-17, 08:02 PM   #3257
yokohama
Try a Fujica if you haven't got one. I'm really liking the ST705 and the stop down metering is a doddle to use once you get used to it.
Nice f1.8 lens on the Konica.
Old 20-04-17, 08:10 PM   #3258
Kenzie
Kenzie's Avatar
It's supposed to be really sharp. I managed to turn the screw around so it is outside in and doesn't mess up the trim. Seen a mint P30 for a tenner as I want the lens.
Old 20-04-17, 08:16 PM   #3259
yokohama
Go for it.
Old 20-04-17, 08:34 PM   #3260
Kenzie
Kenzie's Avatar
Really don't need another body though. Can't believe the prices on XD7s, also seen an X700 for £100!
