Old 27-11-18, 11:13 AM   #6681
timwilky
timwilky's Avatar
Default Re: Gripe of the day - What is yours?
2 more extractions, tender and considering the two from the other week haven't healed yet I cannot eat either side of my mouth now.
December will be a brilliant weight loss month.
Not Grumpy, opinionated.
Old 27-11-18, 12:17 PM   #6682
strewth Tim.. you got gum desese?
Old 27-11-18, 04:46 PM   #6683
timwilky
timwilky's Avatar
Remember the poem by Pam Ayres... I wish I looked after me teeth.
Well I did, but a poor selection of dentists over the years. The four extractions this month have all been failed crowns. Some not lasting a week. Change of dentist and she said those roots have to go. They will only cause you pain in years to come and there is nothing that can be done with them.
Her father is a consultant maxillofacial surgeon, so I suspect she is lining me up for the suggestion of expensive options once the trauma heals
Old 27-11-18, 04:54 PM   #6684
littleoldman2
littleoldman2's Avatar
My consultant maxillofacial surgeon was a dentist before as are several of his team. i'm glad the NHS paid the bill.
Old 28-11-18, 11:25 AM   #6685
Adam Ef
Adam Ef's Avatar
ok since you have a hole then try this. get a hammer drill with a TC tipped masonry drill and use reverse.
the extractor is cone shaped so should reverse out easily enough.
It wasn't budging using any method. Small dremel grinder bits arrived today and I only trashed 2 out of the six I ordered getting rid of the remains of the snapped off "easy out". --- oh the irony of that name!!
I now have the hole back that I drilled through the middle of the bolt. Have got loads of penetrating spray up through the hole into the cavity at the top. letting it soak for a while, then it's going to be loads of heat and trying the left handed thread drill bits which have now arrived too.
How much have I spent on tools to trash trying to fix this? Hoping to move this out of the gripe thread and post a smile later on... hopefully...
Old 28-11-18, 11:42 AM   #6686
Seeker
Seeker's Avatar
Old 28-11-18, 12:07 PM   #6687
Adam Ef
Adam Ef's Avatar
Originally Posted by Seeker View Post
Ha ! Cheers for the vote of confidence!
All my stress has been more worthwhile if it's helping entertain people .. er educate people to not make the same mistakes as me!
Old 28-11-18, 02:10 PM   #6688
knew this would happen... booked in for vascular surgery on 8th Jan.
you cant do vascular surgery till the clot in my heart is away... this requires an MRI.
you cant do vascular surgery till the artery in my ticker has been fixed... this requires me to be off blood thinners for months and then a stent put in.
you cant do vascular surgery till you know if the artery's have been hardened... this requires CAT scans.
you cant do vascular surgery if i'm still on blood thinners....
this is all what i have been told by the leading surgical Mr's.
round and round like being tumbled in a ball.
Old 28-11-18, 07:27 PM   #6689
SV650rules
I have used easyouts with success but they need to be a good brand ( Irwin or similar ) and the secret is not to drill too big a hole in the broken stud or bolt as ( have you have discovered ) there is no metal left to stop easyout forcing the thread into harder contact. This is the dogs dangling bits of antisieze https://www.amazon.com/COP-GRAF-Copp.../dp/B00VM39NC0
2016 SV650 AL7
Old 29-11-18, 10:35 PM   #6690
social worker turned up at my door unannounced about a care review.. tried to ask him questions about care and he avoided answering every single question. the other person that was supposed to be there never even turned up.. the asswipe got me so annoyed i had to ask him to leave. i said politely "look mate its time you left" his answer was "lets get one thing straight i'm not your fukin mate"... what a charmer.
whats ur biggest gripe about the uk? kwak zzr Idle Banter 101 15-11-16 06:33 PM
heated grips gripe adw Bikes - Talk & Issues 8 12-05-10 02:48 PM
