19-10-07, 05:54 PM | #21 |
Re: is my alternator knackered???
I just tested the regulated output on mine, having blamed my cheap battery last night. With main beam on at tickover I have 13.94V and this drops to 13.29V at 5K rpm. Is this the same regulator fault?
23-10-07, 01:12 PM | #22 |
ok......finally the cbr 600 RR arrived....fitted it and now getting..
14.1 at idle 14.2 at 5k i thought they would have been a bigger difference...but i would have though getting 14v would be fine so assume robert is my fathers brother... cheers for all the help resolving this...special thanks to spanner man or id still have bike in bits stu |
24-10-07, 06:50 AM | #23 |
Morning all.
Good show Stooster, a pleasure to assist. It sounds like it's sorted, 14 volts average will do the job just fine, without the danger of overcharging. Chazzyb Your regulator may be developing a fault, although it's not unusual to have the voltage drop a little as the RPM rises. Keep tabs on it, & if you get any sign of a flat battery (providing it's a good battery). You had better check the alternator & or change the RR. Cheers. Last edited by Spanner Man; 24-10-07 at 06:56 AM. |
Astravan alternator | yorkie_chris | Idle Banter | 3 | 08-04-09 10:13 AM |
New Alternator ... How much? | The Bride | SV Talk, Tuning & Tweaking | 13 | 18-02-07 10:34 AM |
alternator dead | Warren | SV Talk, Tuning & Tweaking | 2 | 16-08-06 05:29 AM |
is it my battery? - or my alternator? | branny | SV Talk, Tuning & Tweaking | 18 | 02-05-06 07:43 PM |
battery or alternator? | muzikill | SV Talk, Tuning & Tweaking | 5 | 16-01-06 12:45 PM |
