18-09-17, 07:33 PM | #11 | |
Re: Preload on standard forks & shock
Am on track tomorrow so left the front on max preload with 0 rings showing (this was my concern with a lot of dive when shutting off the gas/braking last time out) & set the rear preload on notch 5 (was on notch 3, didn't notice much movement here, just felt the bike sat quite low), I can go up or back down from here I guess. Cheers, Robbo |
18-09-17, 08:18 PM | #12 |
Unfortunately it's a poor ride on track with your setup, it'll do on the road, but even then the fork springs show up. If you intend to do track days (I don't mean loads, i do 1-2 a year) then I'd look into a GSXR front end, which is relatively easy on a pointy, and an aftermarket rear shock. New fork springs are cheap and easy though, a front end is more of a project, but you'd get the better brakes to boot.
19-09-17, 10:12 AM | #13 | |
There are various articles and youtube videos about fitting other shocks, GSXR are popular. However they all seem to have a remote reservoir at the top which forces you to make a cutout in the battery box. Aftermarket shocks are designed to fit without cutting stuff about. Cheapest one I've found is the Hagon (which I have just fitted to my bike) but the more expensive ones which presumably perform better/longer can cost quite a lot. Then you should really upgrade the forks or you'll still be riding half a pogo stick. The cheapest mods you can do to improve these is to fit K-Tech 9,0 KN springs and 15wt fork oil with a 150mm air gap. |
19-09-17, 05:31 PM | #14 |
Ive read a lot of posts about rear shocks & they are a bit like buying a kitchen,the more you look at the more confused you get.
I am not a speed god & the bike will not be used on a track, how do i know if the original shock is no good? I have been offered a ZX7r that has been serviced for not a lot of money, does anybody know if it will fit & if the ZX7r shock is any good?
He was a hairy handed Gent who ran amok in Kent Awhooo |
19-09-17, 06:53 PM | #15 |
Search! There are endless threads on here about shocks. Bounce the back end, if it pings straight back up then the damping has gone. You'll fail the MoT for it - once they start to go, it doesn't take long. As for replacements, either another bike (search for lists, match the spring weight as best you can, curvies are different to pointies in the respect). For aftermarket, on the road, most will do, you won't notice extra quality between them, but you will notice the difference from stock.
20-09-17, 07:28 PM | #16 |
Ive done a search & got loads of conflicting advice. I am rebuilding an accident damaged bike, the front end is out so I can't bounce the back end & I dont know if the shocks (Ive got 2) are OK or not. I thought that while the bike was in bits I would do any sensible upgrades.
20-09-17, 07:42 PM | #17 |
I'm doing much the same, working on the basis that that standard shock is pretty poor from new, let alone after years of use.
20-09-17, 08:36 PM | #18 |
All you can really do at this point then is check the chrome shaft for oil leakage. Any more than a bit of a tide mark and it's likely to be toast.
21-09-17, 06:48 AM | #19 |
We should arrange a Nitron group buy!
Sent from my SM-G903F using Tapatalk
Black 2010 SV650S Fully faired White 2011 YZF R125 sold |
21-09-17, 04:34 PM | #20 |
OK thanks
Removing shock and want to tidy up preload adjusters questions. | monkey | Bikes - Talk & Issues | 6 | 06-02-11 08:20 PM |
Adjusting rear preload - GSXR100 shock. | bengrrr | SV Talk, Tuning & Tweaking | 9 | 25-08-10 12:58 PM |
ZX10R shock preload adjustment, c spanner? | Elltg | Bikes - Talk & Issues | 8 | 26-02-10 05:56 PM |
New Never Mounted 3 Way Remote Hydraulic Preload Elka Shock | sv-racing-parts | For Sale - SV's and SV related items | 2 | 02-12-09 04:15 AM |
preload adjust on curvy forks? | weazelz | SV Talk, Tuning & Tweaking | 11 | 25-04-06 12:33 PM |
