18-04-09, 06:22 PM | #1 |
Sump washer
Just drained the oil and the sump washer I got from the local H*nda dealer doesn't look right at all. It's got a hump on one side, it's the size of a 5p coin and the hole is wider than the bolt. Are they interchangable? (0916814004 is on the receipt).
I can't get the old washer off either, it won't unwind more than 2 threads from the top of the bolt (it's slightly wavy and quite crushed on top). Ideas on how to remove it without damaging the bolt?
SV650S K5 GSX-R Shock, R6 Throttle, Oxford Hot Grips, R&G Crash Guards, Hugger, Fender Extender, Radiator Cover, Mirror Extenders, Stebel Magnum Horn, DL Handguards, Philips X-treme +80%, Denso Iridium Plugs. |
18-04-09, 06:54 PM | #2 |
Re: Sump washer
its called a crush washer once tightened it flattenes out, i managed to unwind my old one but try and cut it off with wire cutters or something. I cant help you on the size tho sorry
18-04-09, 06:56 PM | #3 |
Re: Sump washer
thats the same sump washer I got from the dealer
HTH |
18-04-09, 09:56 PM | #4 |
Re: Sump washer
at least your Honda dealer gave you the correct size. My Suzuki dealer sold me completely the wrong size washer and i didn't know til i got home and changed the oil.
Sump plug washer - where from? | pencil shavings | SV Talk, Tuning & Tweaking | 26 | 17-03-09 08:52 PM |
Crush washer - which way up ? | Banus | SV Talk, Tuning & Tweaking | 2 | 04-11-07 05:30 PM |
Sump plug washer | yorkie_chris | SV Talk, Tuning & Tweaking | 3 | 29-09-07 10:44 AM |
oil sump bolt washer | lukemillar | SV Talk, Tuning & Tweaking | 8 | 13-09-06 10:22 PM |
Sump washer | The Mass | SV Talk, Tuning & Tweaking | 14 | 27-06-06 09:53 AM |
