Old 18-01-16, 12:44 PM   #1
Alkers
Junior Member
Default Electrical Connector beneath airbox
I've been having on-going issues with my headlights not working. I've traced the problem back to the electrical connector beneath the airbox. If I wiggle this at all, my headlights will come on and off intermittently. I've given the contacts a good clean but the problem still remains and sometimes I've no headlights at all. I've managed to get a quick fix working by cable tying the cables at a certain angle but it will probably fail again soon. I was thinking of just cutting the cables either side of the connector and connecting them up individually but thought I'd first see if a replacement connector was available? Any ideas?
Alkers is offline   Reply With Quote
Old 18-01-16, 12:53 PM   #2
damienga15de
Default Re: Electrical Connector beneath airbox
I'm not familiar with that particular connector but a lot of issues on cars iv found have been rectified by spreading the male parts and closing the female parts making the connection a bit tighter .
Old 18-01-16, 12:53 PM   #3
Corny Gizmo
Is it the green connector? if so, its a well known issue, most people cut the connector out and find a better replacement that is up to the job and wont melt.
Old 18-01-16, 01:16 PM   #4
Alkers
Junior Member
It's not a green connector no and it doesn't appear melted. It's got about 8 wires going into in from either side and includes the ignition circuits etc. I'll try to get a pic up.
Old 18-01-16, 08:23 PM   #5
Toooldtodie
Toooldtodie's Avatar
Just bypass them.
Use decent connectors and weather proof them.
Plenty of info on the forum. From memory (not that good) it's the white and orange ones (they're one on top the other in the block connector). If you look closely you'll probably see the blackened pins where they've been arcing across. Will attach wiring diagram on another post if you need it.
Thought I was in a bad mood, but it's been 30 years now, so I suppose it's just who I am.
05 SV650s now with proper suspension, hurrah!
Toooldtodie is offline   Reply With Quote
Old 18-01-16, 08:26 PM   #6
Toooldtodie
Originally Posted by Toooldtodie View Post
Just bypass them.
Think it's here!!
Nope I'll try again. Invalid file.
Old 18-01-16, 08:32 PM   #7
Toooldtodie
Yellow and white.
Old 21-01-16, 12:42 PM   #8
Ratty
Ratty's Avatar
I've just fixed the problem on my SV1000SK5. It's the yellow wires in the black connector. I extracted the wires from each side and found they were not burned like some. The male a female were very loose when connected and were also corroded. I scraped the surfaces clean and squeezed the female to grip tighter, cleaned all the contacts again and put it all back together. Now working fine. I think this is the wire that turns the lights off during starting. Earlier 1000's didn't have this which I think overloaded the green connector. My green connector is fine after 30000 + miles.
Hope this helps.
Alan
"I can see Paradise by the SV's light"
TCX Competizione S boots saved my foot .
Ratty is offline   Reply With Quote
Old 07-02-16, 07:25 PM   #9
Alkers
Junior Member
Thanks for the comments. I just cable-tied the connection together when looking at it the last time and it was working for a while but has since stopped again.
@Toooldtodie - I can't see anything
This is the connection that is causing the issues:
The connector gets very warm within minutes of the ignition being on.
I guess I'll pick up some block connectors and just replace the entire connection, it's tricky enough to get at though.
Old 07-02-16, 07:55 PM   #10
Toooldtodie
To be honest it is a faff, but in the long run it's worth doing. The main culprits are the yellow and white wires which just need the treatment!
The joy of turning the key and seeing headlights time and again, more than make up for the effort... trust me.
The reason the connector gets hot is it's arcing across the pins... not good!
Identify electrical connector. Stu Bikes - Talk & Issues 4 20-12-10 08:13 PM
Removing an electrical spade from a connector? Grecian SV Talk, Tuning & Tweaking 3 30-05-10 10:35 AM
Electrical connector problem. warrenhewitt10 SV Talk, Tuning & Tweaking 14 08-08-09 11:34 PM
Waterproof Electrical Connector DarrenSV650S Bikes - Talk & Issues 6 04-03-07 08:08 PM
Electrical connector cleaning Ceri JC SV Talk, Tuning & Tweaking 4 13-02-06 07:30 PM
