Old 14-02-08, 01:59 PM   #1
Blue_SV650S
Default 1200 Bandit FRONT wheel bearings
I got a 1200 bandit FRONT wheel to put on my curvy SV650 - thinking I was being clever.
I had read on here that the bearings were a diff size, but swap them and you are away … Sure enough the ID of the bearings is too large; no problem, I pinched the bearings out of my damaged SV wheel, I’ll chuck them in … {family fortunes buzzer sound} eh-errrrrrrrr {/buzzer sound} Unfortunately, the OD is larger than the SV one too (by a fair ways) so it won't go in (well stay in!! ).
Has anyone ever found a bearing that has the 1200 bandit OD (sorry, can’t remember what it was off the top of my head) and SV650 inner?!?!
In short has anyone ever managed to fit a bandit 1200 wheel to a curvy SV??
Old 14-02-08, 03:23 PM   #2
Scoobs
Default Re: 1200 Bandit FRONT wheel bearings
Brammer (Portsmouth) (4.38 km)
Unit F4 Railway Triangle Ind Est, Walton Road, Cosham, Portsmouth, Hants, PO6 1TG
Try these guys. Tell them the OD ID and width and the application and see if they can help you out.
Old 15-02-08, 03:55 AM   #3
21QUEST
21QUEST's Avatar
I'm pretty sure the answer is you can't ........you needed a 600 Bandit but the later one with the same spoke design as the SV ie not the ealiest ones.
Year you want is, 2000 -?.....perhaps it's up to 2004 as if memory serves me right (not sure on this), Suzuki changed the Bandit wheel again. It might actually be a straight swap come to think of it. Have to double check on that as it's been ages since I mocked about with those wheels.
Anyhoos , I might have a Bandit wheel to suit. If the bearings needed changing, then it's already been done as I've had it on an SV.
Ben
Nemo me impune lacessit.
Old 15-02-08, 09:22 AM   #4
Blue_SV650S
Ok, thanks boys for help …
In summery you can get a 47mm OD 17mm ID bearing, its is a 6303. It is 14mm wide unlike the SV that is 12mm and the bandit that is 15mm.
Anyhoo, none of this matters anyway as other measurements simply don’t align with the SV wheel. Like the width where the bearings sit and the width where the discs fit!! …
Anyone want a bandit 12 wheel!?!?
Front wheel bearings Slim666 SV Talk, Tuning & Tweaking 23 30-04-08 08:29 AM
Bandit 1200 rear wheel for sv650 Kulay SV Talk, Tuning & Tweaking 13 14-01-08 08:45 PM
Bandit 1200 rob13 Bikes - Talk & Issues 0 28-03-07 10:37 PM
Bandit 1200 rear wheel BILLY SV Talk, Tuning & Tweaking 19 26-03-06 12:51 AM
Front wheel bearings - £50 fitted at Hamilton MC Dirty Baz SV Ecosse 6 31-01-06 10:47 PM
