Old 14-09-22, 11:10 AM   #1
Seeker
Seeker's Avatar
Default oil filter tightness
Am I a bad person: I have never torqued an oil filter.
Moisten the seal with oil, screw on the filter till it's tight and then one quarter turn more (by hand) - never had a problem.
The Suzuki dealer said my filter was "loose" and I've just ruptured the Yamaha oil filter as the chain wrench ripped through it because it was on so tight. Never had that happen on filters I've fitted.
2016 SV650AL7
2023 GSX-8S
Old 14-09-22, 01:45 PM   #2
Default Re: oil filter tightness
you do it correctly. mechanics are apes and apply the "tight up till almost stripped thread" principle just in case it comes loose and they get sued.
there should never be a need to use a torque wrench on anything but critical components like engine parts. never trust a torque wrench. especially with old or "wet" threads.
i always do another tighten after a few miles.
Old 14-09-22, 05:59 PM   #3
Chris_SVS
Chris_SVS's Avatar
Never done anything more fancy than lube the ring and start screwing
Chris_SVS is offline   Reply With Quote
Old 14-09-22, 06:09 PM   #4
GeorgeRYoung
The stock Suzuki filter says to tighten 2 full turns from lightly seated. The owners manual says the same.
This is pretty tight and makes the filter a tad difficult to remove.
I believe I tightened the last filter 1.5 turns and decided that was tight enough.
65 CB160 (67-69), 69 350GTR (69-72), 72 R5, 73 RD350 (73-84), 82 XZ550 Vision (84-03), 01 Concours C10 (03-19), 89 EX250 (11-14), 00 SV650S (14-16), 03 SV650S (19-)
GeorgeRYoung is offline   Reply With Quote
Old 14-09-22, 06:36 PM   #5
garynortheast
garynortheast's Avatar
Hand tight only for me too.
Fnar fnar!!
Old 14-09-22, 06:44 PM   #6
Craig380
That happened to me with my first SV that had been serviced by the dealer pre-sale.
I do the filter up 'til it touches then an extra half-turn by hand. Never had a leak. The day before a filter change I spray the gap where the filter body is close to the crankcase with a little WD-40, and the filter unscrews easily with just light pressure on the chain wrench.
Old 14-09-22, 09:58 PM   #7
i invested a long time ago in one of those cap filter wrenches. never looked back, they are superb.
Old 15-09-22, 08:06 AM   #8
Craig380
As I'm from Yorkshire, I am obliged to not spend money on new tools, I have to carry on using my dad's old chain wrench or renounce my identity
Old 15-09-22, 01:47 PM   #9
redtrummy
I hand tighten then a bit more. Removing I use a band wrench which I source from the kitchen drawer where ot resides to be used to remove the wife's homemade pickle/jam jar tops
redtrummy is offline   Reply With Quote
Old 15-09-22, 06:02 PM   #10
daktulos
daktulos's Avatar
I tried using one of those once on a tight oil filter ... ended up shredding it. Which reminds me, I still need to replace it.
daktulos is offline   Reply With Quote
Chain adjuster nut tightness? muzikill SV Talk, Tuning & Tweaking 10 18-08-12 02:08 PM
Spark Plugs, oil filter, Air Filter....Curvy 21QUEST For Sale - SV's and SV related items 2 14-01-10 10:04 PM
Checking bolt tightness at service time Tiger 55 SV Talk, Tuning & Tweaking 3 11-07-08 10:17 PM
chain tightness doing my head in... help please ash SV Talk, Tuning & Tweaking 7 25-04-06 09:59 AM
Tightness of nut for bottom yoke gman SV Talk, Tuning & Tweaking 2 06-01-05 06:13 PM
