15-09-17, 09:10 PM | #1 |
Preload on standard forks & shock
Evening all,
Got a 2004 model pointy sv650. Having read several threads regarding the lack of adjustment on the standard forks & shock I understand the only available option is the preload. At 13 stone kitted out I've found it very soft so am going to stiffen up & set the sag accordingly. I have no manual to hand, have searched online & am struggling to find anything to download, so my questions; 1. Forks - rings showing or not for soft or hard? 2. Shock - notches up or down for soft or hard? Thanks in advance for any help. I am aware heavier internals front & different spring back seems to be the chosen fix, but I am just looking to make the most of what's on the bike for now. Robbo |
15-09-17, 10:19 PM | #2 |
Re: Preload on standard forks & shock
1.The less rings showing on the fork preload the more preload (harder)
2.higher notches = more preload, harder Sent from my SM-G903F using Tapatalk
Black 2010 SV650S Fully faired White 2011 YZF R125 sold |
16-09-17, 12:15 PM | #3 |
16-09-17, 12:20 PM | #4 |
your preload adjusters dont make it 'soft or hard' it only adjusts the height of your sag.
less rings on the front = more height taller notch on the rear = more height |
16-09-17, 09:27 PM | #5 |
Do you have the stock fork springs? Because if so then an puppy would find them too soft, on any settings.
17-09-17, 04:10 AM | #6 |
+1 on Bibio, preload wont affect how hard it feels.
Compression damping will affect how hard it feels, but you cant adjust that (apart from new fork oil) |
17-09-17, 12:17 PM | #7 |
Thanks for the help lads.
Yes, all standard springs/hardware. Apologies for the mix up on my terminology of soft & hard, just wanted to set the sag which is now all done. Yep, you guessed it, preload front fully in with 0 rings showing, preload rear on top notch 7! |
17-09-17, 08:59 PM | #8 |
You should get new fork springs, but if the rear is anything like the curvy, 4 or so on preload is fine. The difference with the rear is the rising rate linkage - more preload means a bouncier ride with less damping, a bit less means a better balance of both. Check the damping in the back shock hasn't gone - they don't have a reputation for longevity.
18-09-17, 05:14 PM | #9 |
Check the damping in the back shock hasn't gone - they don't have a reputation for longevity.[/QUOTE]
Ive read about fitting a ZX shock etc but can anybody recommend somebody to rebuild the original shock, if so what's the cost? Thanks
He was a hairy handed Gent who ran amok in Kent Awhooo |
18-09-17, 06:42 PM | #10 |
Fraid orignal SV shock is non rebuildable. Search on here for suitable secondhand shocks or a new aftermarket jobbie....
Removing shock and want to tidy up preload adjusters questions. | monkey | Bikes - Talk & Issues | 6 | 06-02-11 08:20 PM |
Adjusting rear preload - GSXR100 shock. | bengrrr | SV Talk, Tuning & Tweaking | 9 | 25-08-10 12:58 PM |
ZX10R shock preload adjustment, c spanner? | Elltg | Bikes - Talk & Issues | 8 | 26-02-10 05:56 PM |
New Never Mounted 3 Way Remote Hydraulic Preload Elka Shock | sv-racing-parts | For Sale - SV's and SV related items | 2 | 02-12-09 04:15 AM |
preload adjust on curvy forks? | weazelz | SV Talk, Tuning & Tweaking | 11 | 25-04-06 12:33 PM |
