Old 25-10-20, 12:59 PM   #1
Zim
Zim's Avatar
Default Tyre valve
Is it possible to replace the tyre valve when the stem has broken near to where it passes through the rim?
Suzuki SV650S K9
Kawasaki ZZR 400
Yamaha XV535
Yamaha YB100
Zim is offline   Reply With Quote
Old 25-10-20, 01:51 PM   #2
SV650rules
Default Re: Tyre valve
Tyre valves have to be fitted from inside the rim, the end inside the rim is too big to go through hole in rim ( and the pressure helps keep th valve in place and sealed ) - don't know if this will work
https://www.ehow.co.uk/how_6553100_c...ire-valve.html
2016 SV650 AL7
Old 25-10-20, 01:56 PM   #3
Zim
Zim's Avatar
Thanks, good that it's a repair then as the tyres are good. Thanks info.
Suzuki SV650S K9
Kawasaki ZZR 400
Yamaha XV535
Yamaha YB100
Old 25-10-20, 02:19 PM   #4
SV650rules
They should replace the valve every time you get a tyre replaced, it the tyre has an innertube ( most but not all spoked rims have a tube inside ) then the new valve comes as part of the new innertube. Alloy rims should be tubeless and the valve is a separate replaceable part, but sometimes if the alloy rim goes porous and leaks air they will put a tube in.
2016 SV650 AL7
Tyre Valve Extensions? Dunn-y Bikes - Talk & Issues 5 16-02-12 04:34 PM
90° tyre valve adaptors? cluffy Bikes - Talk & Issues 20 30-03-11 05:40 PM
tyre valve just blow out PJinUK SV Talk, Tuning & Tweaking 7 08-06-08 06:07 PM
tyre Valve Change? SV-net Bikes - Talk & Issues 11 08-04-08 05:14 PM
Help!!! Tyre valve has gone awry... Bluesteel SV Talk, Tuning & Tweaking 13 20-04-07 02:16 PM
