Old 31-01-18, 10:37 AM   #1
shiftin_gear98
shiftin_gear98's Avatar
Default Tyre Sealant
Morning Org,
I have a leaky front tyre. No obvious signs of damage anywhere. I plan to swear at it over the weekend - read, take it off to have a proper look.
Clean it all up and put it back on - fingers crossed that this sorts it.
However if it doesn't - it's a pretty new PR3 - I plan on getting some slime or other. I've never used this kind of product.
Have any of you, and what brand did you go with?
Slime
Gloop
Other
Or do you have any words of wisdom as to what I could try to stop the mystery leak.
Old 31-01-18, 10:48 AM   #2
Teejayexc
Teejayexc's Avatar
Default Re: Tyre Sealant
Replace the valve.
Teejayexc is offline   Reply With Quote
Old 31-01-18, 01:40 PM   #3
glang
Take the wheel off and roll it in a bowl of water deep enough to immerse it up to the rim including the valve. Rotate it slowly looking for bubbles as you go - could be puncture, rim or valve....
Old 31-01-18, 03:07 PM   #4
andy650
+1.
Find out where the problem is, before taking it apart.
andy650 is offline   Reply With Quote
Old 31-01-18, 03:26 PM   #5
shiftin_gear98
Yeah I'm liking that idea - thanks glang.
Just got to find a big bucket.
Old 31-01-18, 03:32 PM   #6
embee
embee's Avatar
Personally I dislike tyre sealants, I've had unfortunate experience of them. Others will say different.
Corrosion round the seating area and round the valve pocket are good candidates, I had to completely refinish a pair of wheels which had tyre sealant added due to corrosion round the rim inside and particularly bad in the valve pockets.
I've also had a porous Conti tyre, no traceable leaks anywhere and perfect rim, but it lost pressure. The replacement tyre lost nothing so pretty sure it was the carcass.
Recommend the water bath check first.
Old 31-01-18, 04:38 PM   #7
Teejayexc
Teejayexc's Avatar
Do you have a bath?
Nothing personal !
Old 31-01-18, 07:24 PM   #8
SV650rules
If you don't have anything big enough to get tyre into, brushing water with a bit of washing up liquid in it onto tyre and rim may show bubbles where there is a leak, it is the system gas fitters sometimes use on pipe joints.
2016 SV650 AL7
Old 02-02-18, 10:24 AM   #9
Heorot
My mechanic mate uses water with a bit of washing up liquid in it in a spray bottle to look for leaks.
Some say the cup is half empty, while others say it is half full. However, both are wrong; the real problem is the cup is too big.
Honda 125 CG blown engine Gone to the great mechanic in the sky
Naked SV650 K3 in Silver
Heorot is offline   Reply With Quote
Old 02-02-18, 11:12 AM   #10
Red Herring
Red Herring's Avatar
Ditto the washing up liquid in a bottle advice, rarely fails. Even easier, especially at this time of year, is to find a large puddle and very slowly push the bike through it. Top tip is to wear wellies, unless you really want to find out how waterproof that expensive pair of gortex boots you treated yourself to for Christmas aren't...... Before I did any of that though I'd take the valve cap off and put a dollop of spit in there!
Exhaust Sealant? JESSWOOD2 SV Talk, Tuning & Tweaking 13 03-06-10 08:47 PM
exhast sealant barwel1992 Bikes - Talk & Issues 6 06-10-09 04:53 PM
Thread sealant radicalry00 SV Talk, Tuning & Tweaking 8 18-09-09 06:36 AM
Sealant danf1234 SV Talk, Tuning & Tweaking 4 17-02-07 11:54 AM
what solvent and sealant? lukemillar SV Talk, Tuning & Tweaking 7 11-09-06 04:44 PM
