Old 04-10-04, 10:36 AM   #1
Powergaard
Default Headlight High/Low /Wiring
I know i have posted this before, but I seem to have lost some posts in the weekend.
In your UK headlight, is the low beam on, as well, when you turn on the high beam, or does it turn it selves off automaticly?? what part determines the switch between the two settings ?(high/low)
And any idea on how thick the wiring is from the headlight bulps ??? i have seen the uk Suzuki manual and its not to clear on the subject ?
Old 04-10-04, 11:04 AM   #2
chazzyb
Default Re: Headlight High/Low /Wiring
Yes, and my response went too.
On my naked '99 model, only one filament is used at a time: either main beam or dip. The only time I get both is if I use the 'pass' switch. I don't know what on the faired bikes.
Old 04-10-04, 11:17 AM   #3
Philbo
If it's a 55watt bulb, you will need cable that can safely conduct 4.6 amps, (I=P/V). So a 0.75mm or 1.0mm cable would work for you.
Old 05-10-04, 02:09 AM   #4
Graham
Err, The High, Low beam switch
Front Headlight wiring sub harness (curvy S) Tim in Belgium Stuff Wanted 5 13-12-06 12:25 PM
Naked Headlight Wiring for curvy Ter Stuff Wanted 0 31-07-06 01:21 PM
Single headlight to dual headlight swap Jase22 Bikes - Talk & Issues 2 23-06-06 11:19 AM
High street high side - pics added. Wiltshire7 Bikes - Talk & Issues 91 20-04-05 06:50 PM
Headlight wiring route on SVSK1 mudge32 SV Talk, Tuning & Tweaking 9 19-10-04 12:00 PM
