Old 09-01-18, 02:44 PM   #11
R1ffR4ff
R1ffR4ff's Avatar
Default Re: SV650 K6S wiring diagram required.
Found this?
http://dpippin.com/dl/SV650%20Service%20Manual.pdf
But I think you already have it or similar :/
And an oline one,
https://www.emanualonline.com/Motorb...UaAkkFEALw_wcB
"The pessimist complains about the wind; the optimist expects it to change; the realist adjusts the sails."
Old 10-01-18, 12:02 PM   #12
shiftin_gear98
shiftin_gear98's Avatar
My wife managed to knock it down to 138KB, which alas is still too big. Plus you can't read any of it now.
Duke PM me your email and I'll send it over.
Edit: And yes two fuel sensors no ABS.
SV650K5, K6, SK5 and SK6 European Models
Old 10-01-18, 12:05 PM   #13
R1ffR4ff
R1ffR4ff's Avatar
138k too big?
If I need to send/transfer large files I use a Free Boxnet Account,
https://www.box.com/en-gb/personal
10 gig free space.
Then upload the file to it and send the link to the recipient if that helps?
Also what size did your original scan come out at if you,"Zipped" it?
Old 10-01-18, 01:06 PM   #14
shiftin_gear98
Too big to add to here file size must be less than 125kb to attach to a comment - or something similar.
Thanks for the link R1ffR4ff, However I can't be arsed with setting up ****e like that.
I don't have the patience.
Original scan 1.21 gigawatts.
Old 10-01-18, 01:18 PM   #15
The forum upload thing is borked just now FYI
Old 15-01-18, 04:10 PM   #16
shiftin_gear98
Hello Duke - Hopefully on it's way now.
Old 16-01-18, 09:04 AM   #17
Duke
Thanks Shiftin,
The diagram looks great, all in colour also.
It states that it covers the SV650K5, K6, SK6 & SK6 European models.
As far as the fuel sensor signal is concerned, as I have already checked the tank sensors and resistor pack, that leaves the three electrical connections (at the fuel pump and sensors, resistor pack or the LCD/instrument cluster) or a possible faulty LCD /instrument cluster.
I will check when I next have a chance.
As far as the problems I had with the left and right handle bar electrical connections, all seems to be fixed now.
I have purchased replacement 10Way connectors from Kojaykat to keep in my spares box for next time!
10 Way HM Connector Unsealed
http://kojaycat.co.uk/epages/9500004...bjectID=961760
Duke
Duke is offline   Reply With Quote
looking for wiring diagram for k4 mSquishy SV Talk, Tuning & Tweaking 7 04-04-14 01:17 PM
Sv 650 K3 wiring diagram Itching 2 go SV Talk, Tuning & Tweaking 1 03-05-06 07:58 AM
Wanted: SV650 K3 - K5 Wiring Diagram Mike1234 SV Talk, Tuning & Tweaking 12 09-12-05 09:46 AM
SV650 K4 wiring diagram needed trickdup SV Talk, Tuning & Tweaking 1 28-06-05 08:39 PM
Wiring diagram rictus01 SV Talk, Tuning & Tweaking 0 22-10-04 01:28 AM
Powered by vBulletin® - Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
