18-06-20, 08:12 AM | #11 |
Re: Steering angle change
Topyokes conversion + rise depends on which model Renthal bars you fit.
Or Gilles Variobars and you adjust to taste. None of it is cheap unless you drill the top yoke yourself and that's not advised. Even then you still need new brake lines and clutch cable. Best bet is to watch out for a second hand Topyokes kit. They do come up for sale from time to time.
>>> ? <<< Past: Street Triple 765rs, DRZ400s,GSXR1000 K9, VFR800 A8, ZX6R 636 2006, CRF250L, GSXR750 K7, VFR800 A7, GSXR750 L3, Street Triple 675R, MT09 Tracer, SV650s K8, CB250rsd, YBR125... |
18-06-20, 08:58 AM | #12 | |
As Adam says, or any meaningful rise I'd be surprised if you don't need to extend the cables.
12-10-20, 12:24 PM | #13 |
Junior Member
The gen1 has very lazy geometry standard.
I have droppedfront 10mm and raised rear almost 50mm. Still stable and I don't hang about or like nervous bikes. At 30mm front drop you may bottom out the fork on the lower tripple clamp. Worth checking. |
09-11-20, 10:30 AM | #14 | |
Sags need be reset for reduced travel which in my case meant a .90 spring and 15weight oil and I fitted gold cartridge emulators (optional I think) along with a fully adjustable rear shock the result is WOW |
09-11-20, 05:46 PM | #15 | |
With the 90 springs and 15wt oil how does it feel over bumps n pot holes etc? |
09-11-20, 10:19 PM | #16 |
You could do with steepening the steering a little to make it snappier, but if you just drop the yokes a mile and use stiff springs to stop the mudguard ramming into the bottom yoke it's going to feel like a pogo stick. You're better off just figuring out different bars if all you want is a different riding position instead of ruining the front, which will in turn ruin the rear.
10-11-20, 06:01 AM | #17 | |
No weaving, all cornering slow and fast are great, it doesn't have unwanted dive the compression damping is set with the cartridge emulator which is adjusted as recommended for street. The ride is firm but sure footed and compliant. Doesn't bottom on the bad roads around here, I do lift my weight if i see a big one coming. I have 10 mm of static sag on the rear and 15 mm on the front |
10-11-20, 08:13 AM | #18 |
Also, forgot to say I raised the fork oil level as a further precaution to stop the fork bottoming.
10-11-20, 06:24 PM | #19 |
Is that 10 and 15mm with you on it?
10-11-20, 06:32 PM | #20 |
I too have found my svs to be ' very lazy' in the steering dept, for a bike with this kind of stance I expected it to be a bit more nimble through the twisties, not really a complaint ... more of an observation. Ideally I would just like to raise the clipons to above the top yoke without spending a vast amount but dropping the forks through the yoke enough to mount the clipons safely concerns me enough to think about the front bottoming out with less fork travel, I was kind of hoping it wouldnt be too much of an issue. I already have a spare top yoke that I was going to get welded up and then drilled for risers but my welder has just been made redundant due to covid so .. no can do atm. So now looking for alternative solutions, it's not super high on the priority list of things to do, just getting some info n feedback on what is possible hopefully without spending £180+ on a conversion kit.
Thread Tools | |
From every angle... | -Ralph- | Photos | 21 | 04-11-11 06:38 AM |
Steering lock for Steering damper | Sideshow#36 | SV Talk, Tuning & Tweaking | 8 | 30-08-07 11:18 PM |
How to change the oil in a GSXR steering damper | svrash | Bikes - Talk & Issues | 0 | 18-09-06 05:57 PM |
Lean angle anyone? | Treacle | Photos | 19 | 14-02-06 03:58 PM |
What size angle grinder to change exhaust... | markfc | SV Talk, Tuning & Tweaking | 15 | 24-05-05 06:09 AM |
