Old 22-11-20, 02:24 PM   #1
egcSV650s
Default Oil Loss, too much?
Just checked my oil window and noticed there wasnt anything there, so just topped it up but had to put 800ml of oil in before it got to the minimim mark. My oil light hasnt come on at all and i only done a oil and oil filter change 3500 miles ago. Is this loss normal or is there something i should be worried about? The bike was level when i checked it.
egcSV650s is offline   Reply With Quote
Old 22-11-20, 02:26 PM   #2
Grant66
Grant66's Avatar
Default Re: Oil Loss, too much?
Did you run it after the filter change and top it up?
Sent from an S20 using Tapatalk with that kin cr4p blocked
Formerly known as Gajjii
Previous Bikes: Red Sk1 Curvy, Red MT-07.
Current Bike: Black MT-09.
Grant66 is offline   Reply With Quote
Old 22-11-20, 02:28 PM   #3
egcSV650s
Yes i did, sorry forgot to mention that as its a common mistake that isnt done
Old 22-11-20, 04:26 PM   #4
admin
John T
admin's Avatar
So the oil can disappear for a couple of reasons. Leak, any suspicious puddles under the bike. Burning, any smoke coming from the exhaust?
Did you change the filter?
Old 22-11-20, 04:34 PM   #5
egcSV650s
No leaks from what i can see and i havent really noticed smoke but had the occasional black smoke a few months ago and yes i changed filter at the same time as oil change
Old 22-11-20, 04:44 PM   #6
admin
John T
admin's Avatar
There's quite a lot of oil left in the old filter which is why you check your level after starting the engine to allow oil to get into places like the new filter. As you said that you've done that, I'd just keep an eye on the level for the next few weeks and see if it drops anymore.
Old 22-11-20, 04:53 PM   #7
egcSV650s
Yeah ill keep a eye on it and see what happens. I have just started the bike to look for smoke as cant see it when riding but had the usual white smoke at start (water vapour) but once it warmed up i revved it a few times and its puffing out blue smoke, does that mean burning oil?
Old 22-11-20, 05:05 PM   #8
SV650rules
Yeah, blue smoke is burning oil, black smoke is rich mixture
I found that putting a clean piece or two of A4 paper under bike when it is parked overnight is a good way to see if anything leaking ....
2016 SV650 AL7
Old 22-11-20, 05:11 PM   #9
Grant66
Grant66's Avatar
Blue smoke is burnt oil.
Reving a cold engine might give a bit of blue smoke especially on an older engine.
If there is a problem it'll do it when the engine is hot too.
Old 22-11-20, 05:18 PM   #10
egcSV650s
Ill try that with the paper see if that shows any leaks but for now ill keep an eye on the oil level as ive topped it back to full and see how long it lasts until it drops again
Loss of coolant - why? -Ralph- Bikes - Talk & Issues 17 08-05-12 10:16 AM
Another sad loss Kenzie East Anglian Revolution 5 01-08-11 07:03 AM
Loss of everything - again seedy100 SV Talk, Tuning & Tweaking 14 28-10-06 07:28 PM
a sad loss.... keithd Idle Banter 25 05-03-06 04:48 AM
Loss of power..... Nekkid SV Talk, Tuning & Tweaking 16 21-10-04 05:00 PM
