Old 18-03-10, 08:52 PM   #1
hbaden00
Default Cleaning the carbs and adjusting the valves
Having an issue with my carbs becoming all gummed up and power loss issues. Wondering how many miles should the valves be re-calibrated and if that is the case why not clean out the carbs.
Want to learn how to do it but is it a technical thing to do.
Old 18-03-10, 08:54 PM   #2
Default Re: Cleaning the carbs and adjusting the valves
The valve clearance should be checked every 15000 miles.
Fairly technical, probably not the best as a first foray into DIY, but if you are careful and methodical no reason why not to try.
Old 18-03-10, 10:16 PM   #3
5hort5
I did the valves on my first DIY go as I wanted to do the front CCT and I had no mechanical experience and it was ok with help from here and the manual, although I knackered my carbs when trying to clean the float bowls, still don't know what I did and replaced em with another set. So it can be done but you'll learn as you go along if you know what I mean
5hort5 is offline   Reply With Quote
Cleaning the carbs? Baz SV Talk, Tuning & Tweaking 2 23-10-08 08:33 AM
valves Wideboy Bikes - Talk & Issues 19 12-10-08 11:56 AM
checking/adjusting valves etc.. need help in tadcaster/york/harrogate/leeds area... vzzzbuxt SV Talk, Tuning & Tweaking 4 20-10-07 05:25 PM
Cleaning Carbs SV_Ridin_Newb SV Talk, Tuning & Tweaking 2 13-09-07 10:24 PM
Cleaning up the carbs/rejetting Saracen SV Talk, Tuning & Tweaking 12 06-03-06 12:53 PM
