01-11-09, 08:46 PM | #1 |
Balancing carbs - one way.
Hi All
I found this online, a great set of instructions for balancing the carbs on an SV which may well be on here but I could not find them http://www.bluepoof.com/motorcycles/...svs_carb_sync/ |
01-11-09, 09:03 PM | #2 |
Re: BALANCING CARBS...How to
Aye, it's been up before a few times.
Good run through to give you an idea of what to expect, but that whole site bugs me, it shows one flawed method (for anything they mention basically), and claims it as gospel. That carb balancing method is very complicated. Complicated means points of failure, vacuum leaks and breaking down. Complicated = bad! Much more simple is to just run one tube from front pot, plug it with a bolt when you are not using it.
04-11-09, 12:49 PM | #3 |
Re: Balancing carbs - one way.
FWIW I wouldn't use those gauges, Davida or Morgan Carbtune are worth the money. you only need a pair anyway, for a twin or four (never worked on a triple)
04-11-09, 07:47 PM | #4 | |
I've got a set of Davida gauges, I can't say I'd absolutely recommend them as the damping, which can't be adjusted, is off on one of mine and this make adjusting a little bit more guesswork, although not impossible. MT
Mark T Eagles may soar, but weasels don't get sucked into jet engines. |
04-11-09, 08:17 PM | #5 |
I'd have a 4-set of carbtunes any day. The difference in price is well worth offsetting the pain in the arris trying to do a 4 cyl bike with 2 gauges.
05-11-09, 12:58 PM | #6 |
Fo' shizzle YC, I bought a pair cos I couldn't afford any more! It's just nice to know for those who can't afford 4 decent ones and look at 4 crap ones or a pair of decent ones
05-11-09, 01:06 PM | #7 |
I had a carbtune. The rods get a slight furring on them and they give inconsitent readings. next time you're using a carbtune flick the display and I bet the reading changes.
I set up my BMWs TBs with a Twinmax after getting fed up with the carbtune. Bike was much smoother with the Twinmax. |
05-11-09, 01:14 PM | #8 | |
I like the look of the twinmax gauge though
05-11-09, 01:28 PM | #9 | |
05-11-09, 01:32 PM | #10 |
Yes, I regret selling (or giving away) my Mk1 carbtunes on a bike sale ages ago. But I never thought I'd need them again. Silly me
Selling your ABBA stand, that's plain daft But if people didn't I wouldn't have mine
Balancing Carbs/Throttle bodies | tomjones2 | Bikes - Talk & Issues | 6 | 06-07-07 10:07 AM |
Replacing the Carbs - easy Job? need balancing ? | SpankyHam | SV Talk, Tuning & Tweaking | 8 | 30-06-06 05:42 PM |
Applying vacuum to the fuel tap for balancing carbs? | kciN | SV Talk, Tuning & Tweaking | 10 | 16-05-06 03:27 PM |
carb balancing | Banus | SV Talk, Tuning & Tweaking | 9 | 23-02-06 01:38 PM |
Balancing your carbs | Sir Trev | SV Talk, Tuning & Tweaking | 11 | 08-08-05 08:35 PM |
