16-02-15, 12:09 AM | #1 |
Pointy speedo on a curvy
Will a pointy speedo fit a curvy?
If not is there a better speedo than the trail tech vapor as that looks a bit slow to respond. Thanks |
16-02-15, 03:14 AM | #2 |
Re: Pointy speedo on a curvy
give TamSV a pm. he knows exactly how to wire an inexpensive and very small speedo on a curvy.
orrr why not just use a curvy one. have a read through http://forums.sv650.org/showthread.php?t=153421 |
16-02-15, 04:45 PM | #3 |
Stig put a pointy speedo on a curvy. It's not a straight swap - the wiring and functions aren't all the same so you would need to mess about with the wiring as well as fabbing a bracket for it (as you would with any aftermarket unit). IIRC speedo and main idiot lights were OK and fuel light worked to an extent but I think he had a problem with the tacho.
I've got an Acewell and everything works well after a bit of trial and error. Doesn't work with the standard SV speedo pick-up but I wasn't using that anyway. What's up with the Trail Tech Vapor? Barwel had one on his pointy and recommended it. |
16-02-15, 10:37 PM | #4 |
Thanks for the responses guys.
The trail tech looked to have lag on a youtube clip I saw for the tachometer. If this is ok i would get it? |
17-02-15, 12:28 PM | #5 |
Rev counter seems to the thing that causes some problems with other clocks on SV's. I had some issues with mine jumping around and reading double although I seem to have solved it by rerouting the cable - I think it was picking up a double signal from somewhere.
Barwel also had some issues with the revs jumping but sorted it with a resistor from the manufacturer I think. If accurate revs are the most important thing, you might be best sticking to OEM? |
19-02-15, 09:28 PM | #6 |
I have an Acewell on my curvy, using the original front wheel sensor - in fact I just wired it into the loom, the speed sensor outputs 4 pulses per revolution, so you have to set the wheel circumference to a quarter of what it actually is. Rev counter went a bit mad to start with, but adding a 1MOhm resistor in line sorted it (think that this was described in the manual - seem to remember manual was fairly good). Only thing that currently doesn't work is the fuel gauge, as the SV uses 2 thermistors as sensors for the idiot lights, whereas the Acewell expects to see a 100 Ohm variable resistor. When I can be bothered (and, as it's been maybe 4 years now, it's unlikely to be any time soon), I'll build a circuit using a couple of FETs (or relays) so I at least get some indication.
Mark T Eagles may soar, but weasels don't get sucked into jet engines. |
Speedo Sensor Curvy/Pointy | Blueperson | SV Talk, Tuning & Tweaking | 3 | 02-10-13 04:59 PM |
Pointy speedo rotor fit Curvy? | S.V SCOTT | SV Talk, Tuning & Tweaking | 3 | 12-06-13 11:05 AM |
Pointy speedo on curvy? | hongman | SV Talk, Tuning & Tweaking | 17 | 17-05-10 11:13 AM |
Speedo from a curvy S fit into a curvy Naked housing? | Taipan | SV Talk, Tuning & Tweaking | 6 | 18-02-10 04:59 PM |
Naked Curvy Bottom yoke and Curvy speedo drive | 21QUEST | Stuff Wanted | 6 | 29-01-09 09:36 AM |
