Old 13-08-18, 08:39 PM   #5431
Kenzie
Kenzie's Avatar
I picked this up to repair the other OM1n which just needed a shutter speed ring. This was listed as having prism issues and low speeds not working, but part from the prism it seems in good nick. The lens will need stripping and cleaning but is fungus free. It will need a new prism and a good clean but otherwise ok. Not sure whether to fix this or the OM1n.
Old 13-08-18, 08:48 PM   #5432
admin
John T
admin's Avatar
Is it the prism or focusing screen?
Sent from my Nexus 7 using Tapatalk
Old 13-08-18, 09:04 PM   #5433
Kenzie
Kenzie's Avatar
Its the prism. Olympus fitted a foam seal to the top of it and it degrades over time and takes the silvering with it.
http://olympus.dementix.org/Hardware...val/index.html
Old 13-08-18, 09:52 PM   #5434
johnnyrod
johnnyrod's Avatar
You can get spray-on silver mirror, seen it somewhere, it works fine for reflection from the inside of the glass (like this) but not for reflection from a front-silvered mirror (like the whole or half-silvered ones in rangefinders). Dunno if it would be good enough for a camera but could be worth a try.
Old 14-08-18, 05:16 AM   #5435
Kenzie
Kenzie's Avatar
Might be worth a look, either that or take the prism out of the om1n if its any good. Not sure what to do as I don't want to end up with loads of OM1s trying to fix the previous one!
Sent from my Xperia using Tapatalk
Old 14-08-18, 07:44 PM   #5436
Kenzie
Kenzie's Avatar
More fun
Old 14-08-18, 09:05 PM   #5437
Kenzie
Kenzie's Avatar
And done. Just needs a good clean and meter check.
Old 15-08-18, 04:27 AM   #5438
yokohama
Nice job. Was the solution to do a switch from one of one of your donor OMs?
Old 15-08-18, 05:11 AM   #5439
Kenzie
Kenzie's Avatar
Yeah, took one out of a junk om10.
Old 15-08-18, 07:09 PM   #5440
yokohama
Good to know that the OM10 fits. How's the unpacking and organising going?
