Old 20-11-11, 01:42 AM   #1
Dunn-y
Default Freeing a stuck chain link?
What is the best way to free up a seized/stiff chain link without removing the chain from the bike?
It moves very very slightly so I guess you could probably say it's seized almost. I've cleaned the chain twice with chain cleaner and left the cleaner to soak in for 20 mins before washing off and lubing. It's still really stiff. Would you considering washing, attempting to soak it in paraffin?
Just noticed I put stuff in stead of stiff in the thread title.
Old 20-11-11, 01:45 AM   #2
Destruktor77
Default Re: Stuff chain link...
The way i've always done it was, after a ride when the chain is worm, apply some fresh engine oil to the link(s) with a small brush i.e tooth brush. Let to soak for 20-30 mins, wipe clean and should be free.
Old 20-11-11, 01:48 AM   #3
Dunn-y
Thanks, I'll give that a go, should have a few drips of oil left in the bottle.
Old 20-11-11, 01:59 AM   #4
rictus01
rictus01's Avatar
or even better don't let it dry out in the first place, then it won't go stiff
Old 20-11-11, 02:10 AM   #5
Dunn-y
I lube the chain pretty often so I wasn't expecting to find a stiff link. Think I might invest in a scottoiler next year or something similar.
Old 20-11-11, 03:10 PM   #6
Serdna
Default Re: Freeing a stuck chain link?
400 motorway miles at 100mph will do it, trust me!
Old 20-11-11, 03:41 PM   #7
rictus01
rictus01's Avatar
that's pretty impressive, 400 miles without stopping for fuel
on the odd occasion I've had a bike without a chain oiler; I carry chain lube with me and re-lube at the pump as it takes all of a minute or two.
Cheers Mark.
Old 20-11-11, 03:54 PM   #8
Serdna
Ok smart a** you need to stop for fuel. Actually this is pretty important, the bike stops working at about 150 miles if you don't. They get heavy within a few feet after they stop working!
Cheers Mark.
Old 20-11-11, 04:02 PM   #9
rictus01
rictus01's Avatar
so to take you original statement if you do 400 miles and ignore you chain.....
Old 20-11-11, 04:07 PM   #10
Serdna
You end up with a bike bucking and surging into Amsterdam, and you need to go looking for a new one . And a biking lesson learned. (If you have tight spots in a chain, change it before a long trip)
Cheers Mark.
California, Proposition 19, freeing the weed ! no_akira Idle Banter 86 07-11-10 02:04 PM
chain link tool 01 sv650s Stuff Wanted 0 22-03-09 05:41 PM
Advice on stuck cam chain... jambo SV Talk, Tuning & Tweaking 3 05-08-08 12:36 PM
chain link steveg SV Talk, Tuning & Tweaking 3 30-04-07 08:13 PM
Will stiff chain link cause chain noise dclifford SV Talk, Tuning & Tweaking 8 16-08-05 11:56 AM
