22-01-09, 01:11 PM | #1 |
Front Caliper Piston Service + Fluid Refill
After a drop of the bike (99 SVS), the left hand caliper has been sticking. I have ridden it out and it comes good after a few minutes, but i do not want to risk a seize when i am riding.
I recently gave my back caliper a full service, split the caliper and regreased etc. It was actually a very rewarding job! I want to do my front brakes now and wanted some advice on how similar it will be. Do i split the caliper in the same way? Some other questions - - I don't like the idea of bleeding the fluid dry, would it be best to service calipers then bleed new fluid through after? Or should i empty it out fully and fill up after? Just worried air bubbles will grow in the master cylinder. - Depending on the answer to above, maybe i will do just the left hand side... problems here? Basically, i can either do it myself or pay somebody £30+ to do it... i have fluid and grease, so i will do it myself providing it is not drastically different to the rear brake. Any advice appreciated here guys! |
22-01-09, 01:15 PM | #2 |
Re: Front Caliper Piston Service + Fluid Refill
I think if you are capable of doing the rear you will be capable of doing the front too. If it were me I wouldn't be comfortable just doing one id do them both at the same time, why not eh?
Not sure about the fluid question but again if it were me I would flush out the whole system and start from scratch.
Smokey Black Burnty 02 - Racetech Smoulderlators + .90kg BBQ Springs, zx10r shockingly toasted, Conti Road Attacks heat up very nicely, R&G Crash Bungs but what f**king use are they, No Colour Matched Hugger, Flame Extenda, Beowulf Titainium Oval Flame Thrower. |
22-01-09, 01:17 PM | #3 |
not that bad to be fair fella, just a few more pistons per calliper. personally if u cant afford the bike to be off the road longer than a weekend, buy a set of seals (wemoto personal choice) and split the front calipers, replace the seals and give all the pistons a polish/clean up and bleed new fluid through- the key to this is time/persistance its quite a simple task to do.
22-01-09, 01:33 PM | #4 |
Or you could pay me £25 to do it
Exactly the same as the rear in principle, except with it being a sliding caliper rather than opposed there's nothing to split. Easy to do, get a G clamp, pump them out a bit at a time, using the G clamp to stop the other piston from moving. Get them bothe moving out equally if you know what I mean. Reassemble as for the rear. Do job right and do both sides. You can probably do both in 30mins.
22-01-09, 01:34 PM | #5 |
Same number per caliper. But they are parallel rather than opposed.
22-01-09, 01:36 PM | #6 |
YC if you were closer to me (geographically speaking) id take you up on that offer. I could do it on my own with the Haynes but would be more comfortable having a Pro showing me
22-01-09, 01:37 PM | #7 |
I'm not a pro, just a tight amatuer!
22-01-09, 01:56 PM | #8 |
why would a drop make them stick do you think???
22-01-09, 03:59 PM | #9 | ||
Do you have any advice on how to handle the fluid? Full drain? Quote:
22-01-09, 04:13 PM | #10 |
no but you need to get the slider out and give that a clean/grease aswell, but yeah you can get the pistons out without taking the caliper apart
What to do with Rust in my Caliper Piston Bore | squirrel_hunter | SV Talk, Tuning & Tweaking | 1 | 28-04-07 09:48 PM |
Dismantling a Rear Caliper.(piston removel help req'd) | Grinch | SV Talk, Tuning & Tweaking | 5 | 11-03-07 01:49 AM |
Urgent help needed - rear caliper piston | 01 sv650s | SV Talk, Tuning & Tweaking | 3 | 08-03-07 07:46 AM |
Caliper piston seals | normas_glasses | SV Talk, Tuning & Tweaking | 1 | 31-01-05 08:04 AM |
Single disc with four piston caliper | pridhac | SV Talk, Tuning & Tweaking | 19 | 23-09-04 02:04 AM |
