01-03-09, 08:14 PM | #11 | |
Re: Quick shift
01-03-09, 08:48 PM | #12 | |
Re: Quick shift
During a race its pretty normal to do rapid shifts down the box during the braking zone. Trying to do this without the clutch (and no quickshifter) is extremely difficult to do when you are under pressure. Probably fine to do under gentle riding conditions but I dont really see the point personally. |
01-03-09, 08:50 PM | #13 |
Re: Quick shift
Downshifts are easy tbh. Doesn't hurt the gearbox unless you're a moron.
01-03-09, 09:13 PM | #14 |
Re: Quick shift
01-03-09, 09:15 PM | #15 |
Re: Quick shift
02-03-09, 10:29 AM | #16 | |
Re: Quick shift
I don't understand. Rpm will always be higher in a lower gear at any given speed- if you don't disengage drive and rev match then the revs will be forced up by the rear wheel, and however you do it, you're not disengaging drive if you don't use the clutch (unless you're going from 2nd to neutral -rev- and then to first ). |
02-03-09, 10:59 AM | #17 | |
Re: Quick shift
When changing down, you need to bring revs up a little, so you open the throttle a little. There's a small time delay in that increase in RPM getting to the drive chain. During this time delay there's relatively little load on the gearbox again and you can snick it down a gear with ease. With practice you can change gears both up & down without the clutch, without really unsettling the bike (I find clutchless downshifts easier when I'm hard on the brakes TBH). However: Shifting down without the clutch has far more chance to go wrong. If it goes wrong, the consequences can be pretty severe. |
02-03-09, 11:27 AM | #18 |
Re: Quick shift
I find it quicker to have good clutch control tbh I suspected that I fudged my 675 gearbox by clutchless up shifting so I tought my self to be fast on the clutch, I wouldn't recommend it without a racing or equvilant clutch setup.
02-03-09, 11:53 AM | #19 |
Re: Quick shift
Down shifting without the clutch - I just blip the throttle. It works. Upshifting all the time without the clutch, was useful at getting on the gas early yesterday.
USD gearbox helps too. Last edited by plowsie; 02-03-09 at 11:56 AM. |
Thread Tools | |
Gear shift rod | Sean_C | SV Talk, Tuning & Tweaking | 3 | 21-02-09 08:04 PM |
Shift-I Shift Light | phizog | SV Talk, Tuning & Tweaking | 11 | 09-07-08 12:18 AM |
When do you shift gears ? | mdcvjd | SV Talk, Tuning & Tweaking | 30 | 12-09-07 01:46 PM |
Crash.NET - Capirossi: Quick here means quick everywhere. | NewsBot | News | 0 | 24-02-07 02:40 AM |
Quick Question, Quick Answer | JakeRS | SV Talk, Tuning & Tweaking | 6 | 07-05-05 11:00 PM |
