Old 09-11-20, 08:24 AM   #11
Seeker
Seeker's Avatar
Default Re: Shims / genuine or...?
Originally Posted by Adam Ef View Post
Still waiting on the shims. Hadn't heard a thing since ordering so called them yesterday. Customer service got really arsey with me saying "you only ordered them six days ago!". I pointed out I had no communication from them since the order and she said "well we do say to expect it to be ten to fourteen days". ! I had to ask who they say that to as no one had said anything to me and there's nothing on the website or when you order that states that. She got more and more ****y with me. They won't know anything until sometime next week.. maybe.
Wish I'd ordered from Wemoto now.
...that's not good to hear. I've bought a couple of things from Fowlers (Suzuki) and their customer service has always been great.
2016 SV650AL7
2023 GSX-8S
Old 10-11-20, 07:29 PM   #12
Adam Ef
Adam Ef's Avatar
That's got to be one of the least impressive £90 spend deliveries ever. At least they've arrived. Now just to try and remember how the bike goes back together.
Past:
Old 11-11-20, 04:57 PM   #13
Adam Ef
Adam Ef's Avatar
So.. shims fitted, cams and cam cover and cam chain tensioner all fitted today. Check spec again and the good news is I got 13 measurement and shim sizes right. Not so good news is that 2 are in spec but could be better an 1 is just out of spec still so I need to order another shim for it. The other two that are just within but could be better I can swap around shims for. So... another delay while I wait for delivery of a single shim.
Although frustrating I'm fairly pleased with that for my first ever attempt. Most things I've read about it say that most people will go through the process at least twice first time to get it right and to allow 30 hours to do it if you've never done it before. I didn't believe that but I'm at least half way through that and the bike is still in bits.
Past:
Old 11-11-20, 05:24 PM   #14
Craig380
I can believe it on a 4-cyl bike. First time I checked the clearances on an SV it took me at least 3 hours, luckily no adjustments were needed.
Old 15-11-20, 10:39 AM   #15
Adam Ef
Adam Ef's Avatar
Amazingly I managed to get the ZX6r back together this morning. A few very late evenings and 4 times removing the cams and cover but I've finally got all the valves where they need to be.
Everything connected up. Not find out why the fuel pump isn't priming. All electrics are on and connectors done up. I spent about 2 hours making sure. Tacho goes through start up, but not fuel pump sound. Is there anything I've missed refitting a fuel tank? I had to reconnect the fuel lines so ossibly air in them. Would that cause that to happen? I'd assume I'd hear the pump prime.
EDIT: Pulled error code 35 in diagnostic mode, which is immobilizer amplifier issue.. electrical connector. I did pull apart a connector under the air box that I had to clean up a lot and might have over flooded it with ACF50 when reconnecting. Time to pull off the air box again...
Past:
Old 15-11-20, 03:00 PM   #16
Adam Ef
Adam Ef's Avatar
Damn. Cleaned connectors up and still no priming. Stumped.
Past:
Old 15-11-20, 03:51 PM   #17
Seeker
Seeker's Avatar
You didn't swap keys by any chance?
https://www.zx6r.com/threads/2006-zx...nction.108529/
2016 SV650AL7
2023 GSX-8S
Old 15-11-20, 06:04 PM   #18
Adam Ef
Adam Ef's Avatar
Beauty!
I had the fairing off still and exactly like in that thread, I thought the big block connector was to the indicator. But it's to the immobiliser aerial box.
Sorted. Bike fires up nicely.
It only took me two weeks (off and on) to do the valve clearances. Now on to the bar conversion, brake lines etc etc.
Past:
Valve Shims Dicky Ticker SV Talk, Tuning & Tweaking 6 24-10-11 02:55 PM
Where to buy shims? SUPERSTARDJ01 Bikes - Talk & Issues 4 06-08-11 01:07 PM
Shims yorkie_chris Stuff Wanted 3 14-11-08 01:26 PM
Shims? JakeRS SV Talk, Tuning & Tweaking 16 13-01-06 10:04 AM
Shims bobbydee SV Talk, Tuning & Tweaking 4 13-07-05 05:21 AM
