05-11-20, 11:42 AM | #1 |
2005 sv650s won't start
Well folks how's it going. I ride my sv650 year round here in Ireland. Went out to go to work yesterday and it's not starting. Dash is lighting up, lights come on, hit the ignition switch and I hear 1 click.
I tested using my multimeter earlier and for these readings; Bike powered on battery - 12.14v Attempt to start - 12.30v Relay reading bike powered on - 11.93v Relay press ignition drops to - 0.00 Any suggestions or advice very much appreciated as relying on lifts to work currently. Link to my Google drive folder with video of issue https://drive.google.com/folderview?...iF8wHD8dG36vp4 |
05-11-20, 12:08 PM | #2 |
Re: 2005 sv650s won't start
How old is the battery and what is voltage showing with bike off?
12.1v would be roughly 50% Health, the battery that came with my SV died at start of 3rd season riding it despite showing 12.4v with the bike off. It could be holding charge but have a couple of dead cells so doesn't have the cranking power required. Have you got another 12v battery you could use to try with jump leads? Even a car not running will do. Sent from my Pixel 3 using Tapatalk |
05-11-20, 04:16 PM | #3 |
Hey thanks for writing back.i got the loan if a car booster yoke....can switch it between 12 and 24v and have tried to start the bike with that yoke and no joy...only tried with the 12v setting though....maybe switching to 24v (like a car battery) may give it a better jump? In regards to how old battery is I couldn't tell you. I bought the bike 2nd hand about 18 months ago
05-11-20, 04:37 PM | #4 |
No, car batteries are normally 12v also. If no joy jumping with 12v booster, and no difference still just getting the click then I would look at the starter next.
Assuming you've checked the fuse on the starter solenoid is good. Sent from my Pixel 3 using Tapatalk |
05-11-20, 04:38 PM | #5 |
Do not try 24v!!! it will probably fry your ECU and could damage other things too. Incidentally, car batteries are generally 12v too. 24v, I would think, are mainly commercial vehicles.
05-11-20, 04:41 PM | #6 |
Hey man. Ok on the boosting at 12v only and I've learned now too . The fuse is in good nick, I swapped it with a spare today just to make sure and made no difference. Think I should just swap out the relay for a new one? Should the voltage drop to 0 on the relay when I press the ignition button to start the bike?
05-11-20, 04:45 PM | #7 |
Shouldn't drop to zero but not sure where exactly your taking the reading from.
https://youtu.be/-TJhASgn_uY I know it's not an SV but helped me go through things methodically when diagnosing issues with starting so may be worth a watch Sent from my Pixel 3 using Tapatalk |
05-11-20, 05:28 PM | #8 |
clutch or sidestand switch.
also at this time of year old battery's will show up problems due to the cold weather. |
05-11-20, 07:21 PM | #9 |
I had a car that just clicked - It was the starter motor
05-11-20, 08:02 PM | #10 |
See them 2 screws at 1.57 on the relay. I'm touching the negative and positive of my multimeter to them and getting readings when bikes in ON position and then when I press the ignition switch
2005 SV650s | lemmings999 | For Sale - SV's and SV related items | 0 | 04-04-15 09:57 PM |
K5 sv650s red 2005 | 18sv650 | For Sale - SV's and SV related items | 4 | 09-05-12 03:32 PM |
2005 k4 sv650s | Giffer2 | For Sale - SV's and SV related items | 8 | 18-09-09 12:48 PM |
2005 SV650S | BIGDOGS_SV | SV Talk, Tuning & Tweaking | 1 | 24-11-05 04:25 AM |
The Fastest Man Around The World - START May 24nd 2005 | chewy22 | Bikes - Talk & Issues | 2 | 20-05-05 05:56 PM |
