Idle Banter For non SV and non bike related chat (and the odd bit of humour - but if any post isn't suitable it'll get deleted real quick). There's also a "U" rating so please respect this. Newbies can also say "hello" here too. |
03-12-19, 10:33 AM | #7781 |
Re: Gripe of the day - What is yours?
With separate coil packs the 5000 ohm resistor is normally integral in the spark plug body and the plug will have an 'R' in it if it is an NGK - the denso iridium plug below also has a resistor ( don't know how that is designated in a denso ) and a platinum slug on the ground electrode
https://www.sparkplugs.co.uk/denso-spark-plug-vnh27z
03-12-19, 10:41 AM | #7782 | |
I used non-resistor Caps on my old Hondas but with,"Resistor" plugs
03-12-19, 10:45 AM | #7783 |
John T
With regard to the coil sticks. If you go with another type just make sure you get a good seal on the front cylinders so that water doesn't get down to the plug. I'm not sure that there's a drain hole like the SV.
Sent from my Moto G (5) using Tapatalk
03-12-19, 10:48 AM | #7784 | |
I made my own seals out of some old bike inner-tube and also coat my plugs caps with ACF50
"Stultus est sicut stultus facit" Last edited by R1ffR4ff; 03-12-19 at 10:49 AM. |
03-12-19, 11:02 AM | #7785 | |
The resistor is used to control the rate of rise of current once the arc is started ( the voltage will build up until it reaches a critical voltage to jump the gap, but until the arc actually starts the resistor does nothing because there is no current flowing - rather like a neon with a dropper resistor ) the rate of rise of current is what causes interference to be radiated. So the bigger the resistance the slower to current builds ( it takes longer to discharge the energy stored in the magnetic core of the coil ) , the longer the spark lasts but the spark is weaker - and any contamination of plug with high resistance in circuit is really bad news - so the amount of resistance in circuit is pretty important, which is why ( as you have advised in the past R1ffR4ff ) check the 5K resistance of the plug caps on SV's and if they are approaching or over 8K replace the cap... good advice.
2016 SV650 AL7 Courage is resistance to fear, mastery of fear, not absence of fear - Mark Twain Last edited by SV650rules; 03-12-19 at 11:03 AM. |
03-12-19, 11:11 AM | #7786 | |
The first solution around the late 1970s was the introduction of the,"Resistor Plug Cap" but within a couple of years Manufacturers started making Resistor Spark plugs so in reality the Resistor Spark plug Caps became redundant. It's very very hard to find any non resistor Spark plug Caps or Spark plugs these days as I suspect all the machinery was dis-guarded and it's most likely just as cheap to make the Resistor types of both. I personally dislike the,"R" type plugs caps as they are over-bloated with contact points that can corrode with age and striation:/
"Stultus est sicut stultus facit" Last edited by R1ffR4ff; 03-12-19 at 11:14 AM. |
03-12-19, 06:13 PM | #7787 |
John T
Western power did a survey of the overhead mains power lines running across the bottom of our garden about 5 months ago as my neighbour has a large oak in very close proximity.
"We'll be back to trim the tree" they said "good" said I "but give us plenty of notice" So we've just got back from a two day trip to Northampton to an answerphone message giving us less than a days notice of the work. I can also see a frustrated worker knocking on our door trying to gain access on our security camera. I've no idea if the work has been done as it's too dark to see. If it has then they'd better not be any damage to my property. Sorry to rant here but the stupidity of this really annoys me. A little more planning would would save everyone a lot of wasted time and effort. Sent from my Nexus 7 using Tapatalk
03-12-19, 06:25 PM | #7788 |
We changed suppliers and the cheapest EON tariff required a "smart" meter.
So guy turns up to fit said meter. Couldn't fit it as the meter was incompatible. Left saying he'd pass it onto the change team. Change team arrive a few weeks later, can't fit it because the electricity consumer unit is in the way. Goes away, saying they'll be in touch. They then schedule another visit. Guy turns up and says, he can't fit the meter because the consumer unit is in the way. Told him we already knew that & you were supposed to sort that out. "You need to contact the electricity suppliers to move the electrics." The electricity is supplied by... EON. Sent from my SM-G950F using Tapatalk
Formerly known as Gajjii Previous Bikes: Red Sk1 Curvy, Red MT-07. Current Bike: Black MT-09. |
03-12-19, 06:34 PM | #7789 | |
John T
I've just checked the tree, it has been trimmed but I can't see any mess. On one occasion many years ago they were due to give this tree a trim. They came without notice and whilst I was at home. I only noticed when I looked out of the rear window and noticed my daughter's plastic toy slide was next to the fence under the tree. They used it as a stool to hop over the fence. They also broke the fence. Of course this long after they'd buggered off. Sent from my Nexus 7 using Tapatalk
03-12-19, 08:15 PM | #7790 |
Having to use the bike for work at the moment sick of all the salt on the roads, ride then wash every day, at least it looking good still, anyone use a bike dryer after washing there bike?
whats ur biggest gripe about the uk? | kwak zzr | Idle Banter | 101 | 15-11-16 06:33 PM |
heated grips gripe | adw | Bikes - Talk & Issues | 8 | 12-05-10 02:48 PM |
