Old 23-05-20, 09:04 PM   #11
Biker Biggles
Biker Biggles's Avatar
Default Re: SV650 Curvy - Voltage Regulator / Rectifier supplier?
Originally Posted by NedSVS View Post
I fitted a FH008 from a CBR600RR (2007 IIRC) to my SV650S 2001 nearly 10 years ago now. The FH008 has been fitted to other Honda models too. It fitted in the original place with the fins running in the same direction. I fitted the connectors from my original regulator, as they were in good condition, to the Honda unit. This seems a fair priced one
https://www.ebay.co.uk/itm/Honda-CBR...vlEJTN9w%3D%3D
Just check with the seller it is marked FH008. If you do a search on this forum for FH008 you will see a few have been fitted.
I fitted a CBR600 one to a curvy too. I cant remember the year it came off but it cured the problem and lasted until I sold the bike about five years later.
Old 25-05-20, 07:28 AM   #12
I've got a mofset r/r doing nowt in the shed. Bought one for a job that never happened
Sent from my ELE-L29 using Tapatalk
Old 25-05-20, 01:25 PM   #13
GeorgeRYoung
Another possibility - series regulator:
http://web.ncf.ca/ag136/SV650/seriesRegulator.html
65 CB160 (67-69), 69 350GTR (69-72), 72 R5, 73 RD350 (73-84), 82 XZ550 Vision (84-03), 01 Concours C10 (03-19), 89 EX250 (11-14), 00 SV650S (14-16), 03 SV650S (19-)
GeorgeRYoung is online now   Reply With Quote
Old 27-05-20, 04:04 PM   #14
DickP
Hi
I have installed a second hand rectifier which gave the correct readings when on the bike it has been removed from.
When lights are off, 16.5 volts at idle and hovers around 17v at 5,000 rpm.
When lights are on, 13.5 volts at idle and just below 14 volts at 5,000 rpm.
The results with lights on are within range, whereas lights off is outside acceptable range. Switching between dip and main beam does not change the voltage. Any indicators as to what the problem is?
Thanks,
DickP is offline   Reply With Quote
Old 28-05-20, 08:09 AM   #15
DickP
Hi,
I fully charged the battery and the charging system behaves the same.
I fitted the previous rectifier back on the bike, and now it is behaving as previous with poor charge.
Before I resort to buying another rectifier, can a rectifier be faulty and cause over charging? Or should I be chasing through the motorbikes electrics?
I have also checked the Stator output again and now one of the three connectors is showing a couple of volts less than the other two. Can this be causing the excess charging?
Thanks,
Old 28-05-20, 06:02 PM   #16
embee
embee's Avatar
Originally Posted by DickP View Post
Hi,
…... can a rectifier be faulty and cause over charging?
Yes.
Anything 15V upwards will fry the battery.
Old 28-05-20, 07:39 PM   #17
daktulos
daktulos's Avatar
Originally Posted by embee View Post
Yes.
You need to be a little careful about testing, though. If the R/R has been detached from the wiring loom before testing, it's possible that you'd read a high voltage when there's zero load. At least, that's my understanding!
daktulos is offline   Reply With Quote
Old 29-05-20, 07:51 AM   #18
R1ffR4ff
R1ffR4ff's Avatar
Hi,
Thanks,
Yes. The R/R does two jobs. The Rectifier part changes AC current from the Stator into the usable DC voltage required by the vehicles electrical components and the Regulator part meters/limits the Voltage so is doesn't burn out the components.
More info here,
https://cx500.000webhostapp.com/Mosf...sfetUniRR.html
HTH
Old 29-05-20, 10:21 AM   #19
Dave20046
Dave20046's Avatar
Hi,
Thanks,
Buy a new one. Especially if the second hand one was an sv650 one, they're notoriously bad.
I fitted a tourmax brand new one designed for CBR iirc.
Old 29-05-20, 07:07 PM   #20
buy the proper kit = working bike
or dont but the proper kt = fukered bike
the choice is urs. welcome to the rip off bike world.
Voltage Regulator/Rectifier I'm_a_Newbie For Sale - SV's and SV related items 2 21-08-12 11:57 AM
Wanted: Regulator Rectifier for '99 Curvy SV650 Macey Stuff Wanted 1 07-01-12 09:11 PM
2001 curvy voltage rectifier / regulator leebex Stuff Wanted 14 21-10-11 12:14 AM
Voltage regulator / rectifier Alpinestarhero SV Talk, Tuning & Tweaking 6 16-08-07 03:53 PM
Curvy SV650 rectifier/regulator - box of crap!! Sloth SV Talk, Tuning & Tweaking 4 26-01-06 09:40 AM
