Old 21-09-19, 07:21 PM   #1
tylerb123
Default mis fire help with cylinders please
hi guys random question should both cylinders run by itself without the other on sv650 1999 so if front is plugged in and the rear is out. the front keeps bike running but with front unplugged and rear connected it dies straight away.
i seem to either have a misfire or carb issue but im not sure i have checked plugs leads and coils but not sure what to do any help would be great thank you
Old 22-09-19, 07:15 AM   #2
garynortheast
garynortheast's Avatar
Default Re: mis fire help with cylinders please
Pull the rear cap off and put a spark plug in it to make sure you have a spark at the rear.
How old are the plugs, how old is the fuel in the bike, has the bike been stood unused for any length of time?
Welcome along to the forum, by the way.
Old 22-09-19, 08:37 AM   #3
tylerb123
hi thank you for replying
there is spark at the rear ive checked this.
plugs are only 3-4 months old the fuel is new it was stood for roughly a month fuel is new but was only about about 3-4 litres in there but i took off fuel tank and emptied it but must of been stuff still in carb. who knows
Old 22-09-19, 10:48 AM   #4
Seeker
Seeker's Avatar
I'd suspect a plugged pilot jet on the rear carb assuming the airscrews are set to 2.5 turns out (and the choke plunger hasn't stuck).
Don't forget that carb screws are JIS heads (and seem soft).
Incidentally, there are a lot of fake NGK plugs on ebay, so many that NGK have published a bulletin http://www.ngk-sparkplugs.jp/english...ake/index.html
... and hello, btw.
Old 22-09-19, 02:48 PM   #5
R1ffR4ff
R1ffR4ff's Avatar
Also try swapping the Spark plug caps.If the fault follows you know one if faulty.
The OEM ones are very expensive so I use NGK straights,
Red or black,
https://www.ebay.co.uk/itm/Suzuki-SV...8AAOSwXMZaX~fv
https://www.ebay.co.uk/itm/Suzuki-SV...sAAOSwExlaYlft
Old 22-09-19, 03:16 PM   #6
garynortheast
I suspect R1ffR4ff just forgot to say this, but slosh a good dose of Redex into the next tankful of fuel too.
Old 22-09-19, 03:17 PM   #7
R1ffR4ff
R1ffR4ff's Avatar
Good idea
There's a very happy Lawnmower around here somewhere<grin>
sv 700cc pistons & cylinders jackdoyle For Sale - SV's and SV related items 0 02-12-14 12:46 PM
Fake fire place surround and fire. FREE Ch00 Idle Banter 6 09-09-14 03:26 PM
Cylinders wanted LEXINGTONONE Stuff Wanted 1 11-04-11 05:06 PM
Hills and front cylinders ljharmitt Bikes - Talk & Issues 17 03-04-08 09:54 AM
