Old 13-08-16, 06:53 PM   #1
liamstears
Default Drain plug oil leak fix
So I'm a donut, overtightened oil drain plug
Now leaking slightly, can't get it repaired properly until 31st
Use the bike daily
Quick fix ideas?
Old 13-08-16, 07:12 PM   #2
Craig380
Default Re: Drain plug oil leak fix
Where is it leaking from, around the bolt head itself or from the boss that the drain bolt screws into? Has it made a hairline crack that you can see?
Old 13-08-16, 07:32 PM   #3
liamstears
No cracks I can see, bolt doesn't quite sit straight now so washer is crushed more 1 side than the other and that's causing the leak
Old 13-08-16, 08:09 PM   #4
NTECUK
NTECUK's Avatar
You mean crossed threaded...
Old 15-08-16, 11:52 AM   #5
atassiedevil
Cross threaded or washer is split. Find a piece of copper pipe, make a new washer. Copper is pretty soft and if you hammer it flat, and anneal it it should work fine. Give that a go.
Old 15-08-16, 12:09 PM   #6
Blapper
Blapper's Avatar
Sounds crossed to me. It is a fairly fine thread so easily done.
Plumbers shops sell copper washers...
oil leak - socket bolt next to drain plug. gerrymcghee SV Talk, Tuning & Tweaking 2 14-02-12 07:04 PM
Problems with oil drain plug Grey Rider Bikes - Talk & Issues 8 19-04-10 04:32 PM
Air Cleaner Drain Plug phizog SV Talk, Tuning & Tweaking 11 30-12-07 07:36 PM
where is the coolant drain plug?? hall13uk SV Talk, Tuning & Tweaking 34 25-05-05 04:25 PM
Oil drain plug- Help. Peter Henry SV Talk, Tuning & Tweaking 7 17-10-04 01:26 PM
