Old 15-08-16, 01:55 PM   #1
K5Rider
Default Frame Slider Bracket(s) for left hand of 2005 S
Hi Folks
I think the part I need is called the frame slider bracket.
Basically the bent pipe/bracket thing that bolts to the frame and then bolts through the lower fairing with a slider attached.
Bike got dropped and the left side got really bent. I straightened it back, but it's failed at the welds (rusty) and so not very strong. Can bend it about by hand !!
I'd buy a set if that's what someone has for sale.
Old 15-08-16, 03:34 PM   #2
Default Re: Frame Slider(s) for left hand of 2005 S
take the bracket to your local welder and get them to weld it up for you. those brackets are like hens teeth. alternatively you can get some R&G sliders.
Old 22-08-16, 02:58 PM   #3
K5Rider
Cheers.
Was thinking of just welding it, but I'm lazy !!!
Old 02-09-16, 06:13 PM   #4
liamstears
Did send you a PM, I have a set available...
Frame slider broke on crashing - common? agy Bikes - Talk & Issues 17 20-06-12 01:58 PM
Various curvy bits - Brand new brake pedal and lever, frame slider, standard zorst and others dafne For Sale - SV's and SV related items 16 12-11-10 11:58 PM
Front engine bolt removal/ frame slider fitting Dave20046 SV Talk, Tuning & Tweaking 21 21-09-08 11:44 AM
left hand lower and left hand tail piece malks Stuff Wanted 2 02-06-08 09:56 PM
Frame Slider Bolts rick0361 SV Talk, Tuning & Tweaking 0 26-03-08 10:26 PM
